New stuff from DI - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-06-2009, 04:17 AM Thread Starter
I make smut cry
New stuff from DI
Bought dang time it showed up
Nice lookin piece. Ordered one after I saw Gare's setup.
Powerstroked162 is offline
post #2 of 15 (permalink) Old 10-06-2009, 04:20 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Re: New stuff from DI
What seals it to the tank?
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #3 of 15 (permalink) Old 10-06-2009, 04:25 AM
Banning Smut
PTSUPERD's Avatar
Nice Steve!
PTSUPERD is offline
post #4 of 15 (permalink) Old 10-06-2009, 04:41 AM Thread Starter
I make smut cry
Thanks bro!
I need to gather fittings. What all did you end up using when you ran your FASS?
post #5 of 15 (permalink) Old 10-06-2009, 04:51 AM
Banning Smut
PTSUPERD's Avatar
Thanks bro!
Ask David. I have no clue. I know he knows, because he modeled several other customer installs based on mine.
PTSUPERD is offline
post #6 of 15 (permalink) Old 10-06-2009, 04:54 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Do you normally run a shut off valve of some sort near the sump? *Adds to wish list*
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #7 of 15 (permalink) Old 10-06-2009, 04:56 AM Thread Starter
I make smut cry
Its a two piece flange with a gasket.
Im not going to. Vise grips will do just fine if I need to mess with anything
post #8 of 15 (permalink) Old 10-06-2009, 07:39 AM
Dead Member
Marauder's Avatar
Yep! I'm going to.
Then I'm building a skid-plate with an access hole for the valve and tuck the line up inside of it. So the damn kids don't come by and slit the hose running from the sump to the frame rail.
Out of sight out of mind.....don't need 36 gallons of oil puddled in the driveway.
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
post #9 of 15 (permalink) Old 10-06-2009, 03:17 PM
Moderator
Blowby's Avatar
If you get the DI kit then no way in HeJJ they can cut the fuel hose. Unless they bring a carbon impregnated wheel on a cut-off saw with a long extension cord in their back pocket.
Blowby is offline
post #10 of 15 (permalink) Old 10-06-2009, 03:56 PM
OEM Moderator
Tom S's Avatar
Make sure and post some completed project pictures.
Tom
Tom S is offline
