cant tune WTH - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-03-2009, 06:59 AM Thread Starter
cant tune WTH
ok now I cant get a tune back into my truck. Its telling me "Error check connection". Okay did that about a dozen times now. What else should I look for or what should I do. I have heard that I should disconnect my batteries and that might work?
I think Im done with Superchips. The only reason I have this tuner is that it came with the truck when I bought it. What tuner should I get?
shortycrew is offline
post #2 of 9 (permalink) Old 10-03-2009, 07:51 AM
dinnerbooter treasurer
genuineford's Avatar
Re: cant tune WTH
Get yourself a good custom burned chip from one of the sponsors.
Truck source diesel
power hungry performance
Swamps
Gearhead automotive
Tony Wildman
ect
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #3 of 9 (permalink) Old 10-03-2009, 01:22 PM
All done now
Arisley's Avatar
Re: cant tune WTH
Check your cigarette lighter fuse. It is also the OBDII port fuse.
But yes
Arisley is offline
post #4 of 9 (permalink) Old 10-03-2009, 02:21 PM Thread Starter
Re: cant tune WTH
ok will do. whats the best custom tune? Im not going to go nuts with this truck, I was a safe tune and something easy to take out if i need too. Thanks for your help so far.
post #5 of 9 (permalink) Old 10-03-2009, 02:48 PM
All done now
Arisley's Avatar
Re: cant tune WTH
I like Tony Wildman. 6 position chip, you can have 6 tunes (custom for your truck), all loaded on the chip. Switch tunes as fast as you can turn the switch. On the fly. Any of the tuners on this site will do a good job for you.
Arisley is offline
post #6 of 9 (permalink) Old 10-03-2009, 05:08 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
Re: cant tune WTH
If your going to get a custom tuned chip and want to get the chip cheap and pay whatever it cost for custom tunes youll definatly need a TS style chip as almost ever tuner uses them and Ebay has a greay deal on them thats what I did and was brand new came with standard ts tunes on it and when I bought my injectors from swamps I got swamps tunes put on it for free because I bought my injectors from them. so in the end I came out like close to 300 dollars cheaper than what most people pay. for brand new chip with swamps tuning
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #7 of 9 (permalink) Old 10-03-2009, 05:43 PM
Re: cant tune WTH
More and more people will have this issue with the OBS trucks as time goes by. I don't recommend reflashing OBS trucks ever unless it is a completely reman computer. At ten years of age the components in the PCM start allowing the clock speeds to vary and when that happens you will get flash failures.
In most cases you can run a chip on a "failed" flash computer and resume normal operation.
mattr66 is offline
post #8 of 9 (permalink) Old 10-04-2009, 06:11 AM Thread Starter
Re: cant tune WTH
I unhooked the batteries for about 10mins and tried again and it took the tune, I still will look into a better tune cuz this Superchip SUCKS...
post #9 of 9 (permalink) Old 10-06-2009, 01:53 AM
PHPDiesel's Avatar
Re: cant tune WTH
Wanna part with it?
Cody
PHPDiesel is offline
