biggest single shot injectors with stock turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 44 (permalink) Old 10-02-2009, 04:19 PM Thread Starter
Banned
So what would that be guys, just curious. I have heard that singles get you better fuel economy.
sideswipe7 is offline
post #2 of 44 (permalink) Old 10-02-2009, 04:31 PM
Deputydog's Avatar
Re: biggest single shot injectors with stock turbo
I'd say you're ok with stage 1's, stage 2's will kill it off in short order.. I suppose it all depends on how heavy the foot gets on the pedal.
Deputydog is offline
post #3 of 44 (permalink) Old 10-02-2009, 04:31 PM
The Fireman
big_stroker's Avatar
You can go with any size you would like. Its all in the tuning.
But what ever injectors you get will not last long with a stock turbo.
big_stroker is offline
post #4 of 44 (permalink) Old 10-02-2009, 04:40 PM
BrownBrothersPullingTeam
farmboy8201's Avatar
well, im not sure what the biggest is, but we put 175cc single shot injectors in my brothers late 99 psd, he is running a stock charger, custom tunes, and exhaust, and the truck is hooked to a gooseneck almost everyday, its a crew cab 4x4 dually with 3.73 gears, just to give you an idea, but im thinking he gets around 16mpg just driving around, and he just brought a 1206 international tractor back from wisconsin, and averaged 11mpg loaded...
1999 F350 Lariat extended cab long bed dually, PSD,ported heads, studs, gen 3, 38r/1.15a/r, 300/100, and more Tuned by Matt owner of Gearhead Auto. Perf, John Woods Trans.
2006 F250 XLT 6.0
dual exhaust, egr delete, arp studs, regulated return kit, Modified Direct Clutch Solenoid, SCT Flash custom tuned by Matt, 58 volt FICM w/PHP Flash
farmboy8201 is offline
post #5 of 44 (permalink) Old 10-02-2009, 04:48 PM Thread Starter
Banned
well who would you guys say has a good injector reputation.
post #6 of 44 (permalink) Old 10-02-2009, 04:55 PM
There are alot of good guys out there, but i get all my injectors/injector builds from Nate at Unlimited Diesel Performance, he does a great job!! give him a call, he can help you out 1-740-569-1319
2006 F250 XLT 6.0
post #7 of 44 (permalink) Old 10-02-2009, 05:03 PM Thread Starter
Banned
I am not heavy on the gas peddle it costs me 75$ to fill my tank. I use cruise all the time and only run at 65mph. I drive mostly freeway to work and back.
post #8 of 44 (permalink) Old 10-02-2009, 06:05 PM
The Fireman
Another vote here for Nate at Unlimited for Injectors. And if you are going to run his injectors I highly recommend Matt's tuning to go along with them.
post #9 of 44 (permalink) Old 10-02-2009, 06:47 PM
NorCalDiesel's Avatar
$75 to fill your tank? $75 gets me 25 gals of Diesel. That leaves me 19 gals short in this Excursion. Pumps only go to $100 where I am if I'm lucky. Always takes two card swipes to fill up completely.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #10 of 44 (permalink) Old 10-03-2009, 03:18 AM
I love my 175/146 singles I got from Dave at swamps. Great people and great products. My Excursion still has the stock charger and seems to be ok for now. I'm sure the sticks will shorten it's life a little. If it does, that's the price to play I suppose.
2001 Excursion Limited, Swamps 175/146 singles, John Wood tranny, UltraLite Gauges, 4" turbo back, AFE stage 1, Dp tunes, 7" Superlift, Fox Shocks, Firestone Airbags, 35"Toyo M/t...blah,blah,blah
SmokeWagon is offline
