7.3 ccsb f350 towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 03-27-2015, 04:33 AM Thread Starter
Ok, guys here's the deal. I tow a lot with my PS, but also like to drive it as a DD to. Its not my only vehicle but my favorite. I tow a 24 foot low pro gooseneck weekly and a 40 footer loaded with two to three sand trucks once to twice a month during the April to October. The little gooseneck is now problems. But the big one is kicking my trucks ass.
About the truck:
Its a 2001 F-350 crew cab short box. I'm currently running a 6637DIY intake, 4 inch turbo back into duals no muffler and a PHP chip. All the tunes are the free ones they provide. I have a CTS insight to monitor all of it.
Problem:
When towing the big gooseneck. My trans temp is wanting to be around 215 - 225. This seems high but I was told it was ok. The truck is loosing power when climbing some of the hills which are quite big at time. I can be at 65. And it'll down shift till I'm at 40 mph. If I up my tune for more power my egt's go crazy. My probe is tapped into my drivers side manifold. I need help to keep trans temps and egt's down. I now it could get pricey. But I'm ok buying things one at a time until I'm where I need to be.
THANKS in advance
erstroke is offline
post #2 of 25 (permalink) Old 03-27-2015, 04:46 PM
All done now
Arisley's Avatar
Re: 7.3 ccsb f350 towing
How much does the big gooseneck and load weigh. Sounds like you need more truck for it.
Might be able to throw some lower gears in the diffs.
Arisley is offline
post #3 of 25 (permalink) Old 03-27-2015, 04:55 PM Thread Starter
Total load for the goose and average load is 21,000 lbs.
erstroke is offline
post #4 of 25 (permalink) Old 03-28-2015, 12:47 AM
Colorado's Avatar
You are way over loaded, you need a bigger truck. A 38R turbo, NO exhaust leaks, NO boost leaks, 6.0 tranny cooler and good valve body should cure your heat issues.
97 F350 4x4 - SWAMPS
01 F350 4x4 - SWAMPS
01 F450 4x4 - 4.88's
Colorado is offline
post #5 of 25 (permalink) Old 03-28-2015, 10:40 AM Thread Starter
What's next a Daully? For the trans cooler would it be a waste of Time and/or money to throw a fan behind it for extra cooling? Any suggestions on the valve body?
erstroke is offline
post #6 of 25 (permalink) Old 03-28-2015, 11:52 AM
That's a helluva lot of weight for srw. I have cc srw 01 7.3. I've never pulled that kinda weight. How does it handle it as far stability? Braking? I'd look into exhaust brake to with that much load.
Cookieone is offline
post #7 of 25 (permalink) Old 03-28-2015, 01:34 PM
A tru cool trans cooler is only about $140 and keeps us under 160* while towing. But 21k is way too much to tow safely with a srw.
hoschtonhauler is offline
post #8 of 25 (permalink) Old 03-28-2015, 01:44 PM
<---Peggy Sue
moose7.3IH's Avatar
I think it's time for a medium duty truck to be able to haul safely!
e99 f350cclb lariat 4x4 zf6 ranchhands
leveled
4" dp 5" straight pipe
ccv mod
cai
Rosewood 180/100 single shots
Terminator t500 hpop
Garrett 38r with all the late 99 goodies
Currently
79 bronco 400m c6 8" lift 5.13s welded rear Detroit locker up front 38.5" tsls for the trail 35" bogger/buckshots for the mud bogs
moose7.3IH is offline
post #9 of 25 (permalink) Old 03-28-2015, 02:30 PM
Here for the party....
The trailer, loaded, without the truck in the equation is 21k?? Or truck, trailer, and sand trucks is 21k??
If the whole combo loaded up is 21k, that is not way over weight. And there is no need for a medium duty, or any of that horse ####. I grossed 31k a couple of times with my '02 ccsb, helping a buddy of mine relocate livestock with a 32' triple axle gooseneck, and it handled the weight, and pulled it down the road just fine. Trailer had 3 braking axles, and I ran the brake gain way up, and it stopped fine. Towing my enclosed car trailer, that put it just up over 20k gross, it would run through Texas, and Oklahoma, and New Mexico effortlessly. Set the cruise at 70-75, and let it do it's thing.
2015 Chevrolet Tahoe, Crystal Red Tintcoat, LOADED
2014 Ford Mustang GT, 5.0, Race Red, 6 speed
Currently Stroke-less
Al Mighty is offline
post #10 of 25 (permalink) Old 03-28-2015, 07:01 PM
I can see the whole combo deal. And I wouldn't sweat pulling 20k through Texas and Oklahoma. But I don't see you climbing Fancy Gap 9 mile hill in 30mph wind and feeling safe. Or crossing the Rockys. You might be able to but your butthole would tight as Nuns cooch! Lol!
Giver hell it either will or won't!
Funniest thing I ever saw: friend of mine upgraded a Chevy 1/2 ton and pulled a 36' Holiday Rambler all over the Rockys. And out pulled a lot of our PS. So hey, Anything is possible!
