Holy Water Batman! My first time towing w water.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-02-2009, 01:51 AM Thread Starter
Talking Holy Water Batman! My first time towing w water..
This is also kinda part of my earlier thread, but also my first impressions of towing w water.
Here is the link to my other thread.
What size line is everybody using on their water injection? - Powerstroke Nation
I can now say that I'll never tow w/o water again if I can help it. I have had the water installed on my truck for about 2 months now, and today was the first time I had a chance to pull my Toyhauler (24k gross).
I brought it home from Santa Barbara to Valencia (roughly 90 miles) to get ready for a family vacation. My EGTs were so much better than before that I found myself running at 75mph+ and 25-30psi just because. The EGTs would start to climb, then the water came on and they just dropped. Even holding OD @ 2k RPM was easier. Before the EGTs would keep creeping up, and unless I got up in the Revs or downshifted, they would keep going up.
Here's the crazy part. I got the biggest 7gal tank that CM offered. Before I left w the trailer today, I filled it to the very top. About 5-10 miles from home I noticed that my EGTs were getting hot and I had to let out of it to keep them down. I looked and the duty cycle was at 75%, but I had no flow from the flow sensor. I thought that something must had plugged the line or the line popped off. All I know was that all of the sudden there was a huge difference in the way the truck pulled.
When I got the the RV park where I dump my tanks, and while the poo was flowing, I hopped in the back of my truck and sure enough, the tank was empty. I checked all the lines, and everything was good. So that's 7gal in less than 100 miles. I got better fuel mileage than water mileage
I called CM and asked what the normal range of the 7gal tank was, and they said typically 300 miles. It turns out that I am flowing about 1200-1300cc, which is 500cc more than they usually run w my setup (and that's on one pump). All I know is that it worked.
I am going to play w the map and see if I can start the pump at 25% instead of 50% and maybe hold the max output to 80% just see if I still get the cooling, but save a bit of water. I'm also going to get a 15-20gal tank to make sure I don't run out again.
So to sum things up I have to say that so far, I'm way happy water.
99 F350 CCLB
skav is offline
post #2 of 9 (permalink) Old 10-02-2009, 01:56 AM
06powerstroke's Avatar
Re: Holy Water Batman! My first time towing w water..
Sweet Sean! Your makin me want to do it! What were before and after egt's?
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #3 of 9 (permalink) Old 10-02-2009, 02:19 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Awesome to hear! I have water on my list high at the top.... I run very hot, and water will seriously benefit me.. What size nozzles are you running and how many?
Stock
PowerstrokeJunkie is offline
post #4 of 9 (permalink) Old 10-02-2009, 03:10 AM
jkidd_39's Avatar
Which kit are you running? CMGS Stage 3?
2002 F-350 CCLB 7.3 250,000 Miles *** 5" MKO Power Exhaust, 6637, Foil Delete, DB's HT Starter, EV2 Gauges, 6.0 IC/TC, Van Turbo, WW, Casserly Stg. 1 Singles, BTS VB, DP Tuner, HPX***
2008 F-450 CCDRW 80k ***4"DP-5"MBRP, S&B Intake, Elite EGR delete w/ wastegate, Elite Studs, DPF/DOC delete, KEM 345***
jkidd_39 is offline
post #5 of 9 (permalink) Old 10-02-2009, 03:47 AM Thread Starter
I have two 380cc injectors on the runners before the plenums and one 500cc right before the Y.
yes, but I added the solenoid and flow sensor. I couldn't tell if it was injecting or not w/o.
99 F350 CCLB
skav is offline
post #6 of 9 (permalink) Old 10-02-2009, 03:49 AM Thread Starter
They were probably a couple hundred higher, but the main thing is that you can stay in it longer while pulling.
99 F350 CCLB
skav is offline
post #7 of 9 (permalink) Old 10-02-2009, 05:16 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Love water injection... Been saying that for years!
Joe
CSIPSD is offline
post #8 of 9 (permalink) Old 10-06-2009, 03:36 AM
01platinum's Avatar
Guess I am going to have to start looking into this whole water thing.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #9 of 9 (permalink) Old 10-06-2009, 05:47 PM
Village Idiot
southmike's Avatar
seen a new aem pump that talked about recirculating design
any thoughts on if that is good thing or not.
southmike is offline
