fuel sytem help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-01-2009, 05:09 PM Thread Starter
fuel sytem help
im building a fuel system for my truck right now from the tank to my regulated return line kit. this is what i got so far fabbed up a fuel sump then i got a fleet guard fuel water seperator and one of there 2 micron filter for the bowl delete. i using 6 an push lock hose and fittings for the rr kit on the engine but my question is what size line should a run from the tank to the filters and pump. and should i up size the return line to a 6an. i still got the stock pump for right now because it still works but will get a walbro when needed
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #2 of 4 (permalink) Old 10-01-2009, 06:41 PM
A Ghost these days...
farm boy's Avatar
Re: fuel sytem help
Use a 5/8" line from the sump to the filters, then 1/2" or 3/8" from the filters to the engine. You should probably upgrade the return to 3/8" IMO. For the return hose, you can get by with some SAE 30R6 hose since there is not any pressure on it to speak of.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #3 of 4 (permalink) Old 10-01-2009, 08:22 PM
Milk Truck
abianca99's Avatar
Re: fuel sytem help
99.5 F250 cclb 4x4...modded, but looks stock
abianca99 is offline
post #4 of 4 (permalink) Old 10-02-2009, 03:08 AM Thread Starter
Re: fuel sytem help
thanks exactly what i needed to know
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
