Boost fooler gtp38r how many turns on waste gate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-24-2015, 04:37 AM Thread Starter
So I'm wanting to do a boost fooler on my gtp38r. Does anyone know how many turns is required on the waste gate to keep it closed?
Harrison3458 is offline
post #2 of 6 (permalink) Old 03-26-2015, 11:19 PM
Re: Boost fooler gtp38r how many turns on waste gate?
As tight as you can get it.
I think the paperwork that comes with the turbo says to close the wastegate flap, adjust the rod to where the rod end easily slides over the pin, then screw it in 6 full turns and apply pressure to the wastegate cylinder until it slides over the pin. This gives it some pre-load. However, 6 turns is not enough and it will open really early. I did at least 12 turns on mine then put compressed air to the wastegate cylinder until it lined up. I do not even have the red hose connected.
You are not going to hurt a 38r with stock or slightly upgraded injectors, so there is really no need to have a functioning wastegate.
post #3 of 6 (permalink) Old 03-27-2015, 12:50 AM Thread Starter
So what you're saying is. Screw it as tight as it can go but still be attached?
post #4 of 6 (permalink) Old 03-27-2015, 12:56 PM
POWER Junkie
PSD POWER007's Avatar
Put air on the WG nipple so that the arm fully extends. Then thighten the arm down till it lines up with the pin while the flap is closed.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #5 of 6 (permalink) Old 03-27-2015, 01:19 PM Thread Starter
Sweet thanks man.
post #6 of 6 (permalink) Old 03-27-2015, 06:59 PM
Yes exactly. Use the method described by PSD POWER007.
