FueLab vs A1000 Sound - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 10-01-2009, 02:19 AM Thread Starter
Busy Busy
Marty's Avatar
FueLab is a HELL of a lot louder.
Both set at 70 psi. Same regulator, same entire fuel system from pickup tube to fittings in the heads. Same exact wiring w/ relay and fuse and wire gauge.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 39 (permalink) Old 10-01-2009, 02:22 AM
PSN Pretender
907DAVE's Avatar
Re: FueLab vs A1000 Sound
WOW......
907DAVE is offline
post #3 of 39 (permalink) Old 10-01-2009, 02:31 AM
Big Sky Groomer Op.
ford7.3sd's Avatar
wow, that is quite a bit louder..
Go Army!
Tyler-
2001 F-350SD XLT SC,LB 4X4.
DIY intake, Tuned by deoblo
,gauges(boost,trans,piro), 5 inch MBRP,4 inch superlift and 37 inch ss m16s and sportin the 05 headlights.
E-99 F-250SD lariat SC,SB 4X4.
lots of dents a plow, in need of some love.
95 Chubby Blazer 4X4... pile.
ford7.3sd is offline
post #4 of 39 (permalink) Old 10-01-2009, 02:35 AM
Cummins Power
mech2161's Avatar
I've never seen an A1000 that quiet.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #5 of 39 (permalink) Old 10-01-2009, 02:56 AM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
My A1000 is pretty quiet too and it seems to be holding up just fine. Mine pump is 2 years old and it only drops a few psi at WOT.
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #6 of 39 (permalink) Old 10-01-2009, 03:01 AM
70 psi sounds aweful high to me, have you tried backing the pressure down and see what the sound does? I ran mine at 60 psi. with taht being said, when i first turn my key on i can hear the pump start but once the truck is running i cannot hear the pump inside the cab or while standing outside of it.
edit- video just loaded and i watched it, id send that clip in to fuel lab and let them hear that. your pump is WAY louder than the ones ive heard, might be a problem with it.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #7 of 39 (permalink) Old 10-01-2009, 03:35 AM
Milk Truck
abianca99's Avatar
I have heard two fuelab. One of them is mine, which is on the video. They both sound the same. Similar to some videos that were posted not long ago. I have been told that the A1000 is way louder. But, from what I have heard, it's the other way around. It doesn't bother me. It's just what I have noticed from personal experience.
99.5 F250 cclb 4x4...modded, but looks stock
abianca99 is offline
post #8 of 39 (permalink) Old 10-01-2009, 03:37 AM Thread Starter
Busy Busy
Marty's Avatar
The A-1000 on Johns truck sounds the same as mine. Also, I've heard 3 different FueLab pumps with two being on the same truck and they've all sounded the same. In fact, the FueLab video's that have been posted recently sound exactly like that one.
Both the FueLab and A1000 we have been messing with pressures with... so far we've been bouncing around 65-70.
Elkton, Maryland
Marty is offline
post #9 of 39 (permalink) Old 10-01-2009, 03:52 AM
Milk Truck
abianca99's Avatar
Videos of different pumps would be appreciated. It would give us all an understanding of what thedifferent pumps sound like. I have noticed that changing the fuel pressure changes the pitch of the pump, but not the volume(loudness).
post #10 of 39 (permalink) Old 10-01-2009, 03:55 AM
check that, mine was set at half speed unless the hobbs switch kicked it to full speed. I never ran mine at full speed w/o the truck running/ hauling ass, i couldnt hear anything but the turbos anyway lol
2013 ccsb 4x4-stock
