shim fpr, now leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-30-2009, 10:16 PM Thread Starter
shim fpr, now leak
Sunday I did this to my 99.5 : http://www.dfuser.com/Install%20Guid...tor%20Shim.pdf only I used a BB. Everything went fine. I put 100 miles over 2.5 days, and no prob. Now when I left for lunch today fuel was poooouring out the lid of the filter (around the oring).
I R&R'ed the filter (same filter) , and leak stopped, I drove 1 mile shut off-no leak, start up 5min later, no leak, drive .5 mile no leak. Shut off, 40 min later, start up, badddd leak, the oring had popped out. Then I installed new filter, drove 1 mile, shut off- no leak.
The o-ring on the old filter looked swelled, and the filter was due replacement anyway.
Did the BB FPR have anything to do with this, am I going to have this prob in another 100 miles or is the leak just coincidence.
new to me truck:02-99 f350 cclb 4x4 6sp bdp stg 1's, TW 6 pos chip, diy tymar everything else stock, that I know of, talk about bassackward upgrading, but I wanted my NEW stg1's in my 'new' truck
1064rg is offline
post #2 of 13 (permalink) Old 09-30-2009, 10:26 PM
moore20017.3's Avatar
Re: shim fpr, now leak
I have had mine shimmed for many thousand miles with no problems.
What size BB did you use? I used a 4-40 screw with the head machined down to like .070'' IIRC. What is your fuel pressure?
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #3 of 13 (permalink) Old 09-30-2009, 10:49 PM Thread Starter
bb gun size, no gauge
1064rg is offline
post #4 of 13 (permalink) Old 10-01-2009, 12:45 AM
Clyde's got it
Huck's Avatar
0.171 to 0.173 inches
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.
6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats, PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, EOT, pyro, boost, and Trans temp, Diy Coolant Filter, TrueTrac, Terminator Modded 17* HPOP,
Huck is offline
post #5 of 13 (permalink) Old 10-01-2009, 02:16 AM
PSN Pretender
907DAVE's Avatar
Mine did the same thing, very annoying. Ended up getting the new filter design that napa sells, comes with a redesigned lid and gasket. Stoped the leak but kinda pricey, I think it was like $50.
Good luck
907DAVE is offline
post #6 of 13 (permalink) Old 10-01-2009, 04:14 AM
Starting Over
kainers's Avatar
bb mod is ONLY for the OBS trucks NOT super duty.You are probably if you pump can handle it at 100psi of fuel psi.I have a few pics in my webshots of my fuel spray disaster that in the end cracked my fuel filter lid cause I kept tightening it down harder and harder to prevent the leak.
kainers is offline
post #7 of 13 (permalink) Old 10-01-2009, 04:46 AM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
I used and allen head bolt in mine. Ive heard of guys using the bb in their SD and having disaster. Only a obs mod. SD need the allen head and you need to check what the fuel pressure actually is.
SMOK'N BLUE STROKER is offline
post #8 of 13 (permalink) Old 10-01-2009, 10:17 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
BB= over 100psi. on SD.You should never shim it until you can check the fuel pressure.Theres a port on the back of the fuel bowl you can screw a gauge in there.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #9 of 13 (permalink) Old 10-01-2009, 02:26 PM Thread Starter
I will try to get the bb out soon.
I drove 20 miles home, 20 back to work, and no leaks so far.
1064rg is offline
post #10 of 13 (permalink) Old 10-01-2009, 03:58 PM
I would get it out of there before you trash the pump.
