holset turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 09-30-2009, 01:26 AM Thread Starter
co04cobra's Avatar
holset turbo
Can anybody tell me anything about this turbo? Can it be made to work on anything. etc etc.
co04cobra is offline
post #2 of 26 (permalink) Old 09-30-2009, 01:32 AM
Got Bost???
NyCowboy87's Avatar
Re: holset turbo
Its a vg turbo. Probably not worth the effort to try and make work on a psd, or anything that is not already setup with a vg turbo.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #3 of 26 (permalink) Old 09-30-2009, 02:03 AM
FordBoy86's Avatar
Re: holset turbo
I work at a Mack dealer, i'll get the numbers and see what specs i can come up with for you. Worse come to worse you can always sell it to someone with a Mack and get some money out of it.
'94 F-350 4x4 DRW 5spd
Intake, DP, IDM Mod
FordBoy86 is offline
post #4 of 26 (permalink) Old 09-30-2009, 02:17 AM Thread Starter
co04cobra's Avatar
Re: holset turbo
Its a brand new turbo let me know what its worth. Or any other uses for it? Or the Hp truck and motor its for.
post #5 of 26 (permalink) Old 09-30-2009, 07:34 AM
Fierro Racing
BeastPowerX10's Avatar
Re: holset turbo
its the same turbo of a cummings, 8.3's(change them all the time) or a 60series DDEC VI engine (same turbos)
couldnt tell ya what there worth.
does it still have the acutator and the shaft speed sensor?
2008 rclb Tow Rig Edition
71 Gated Deleted
Hallers Diesel Performance
Who Needs Swagger When You Got Stagger
BeastPowerX10 is offline
post #6 of 26 (permalink) Old 09-30-2009, 02:57 PM Thread Starter
co04cobra's Avatar
Re: holset turbo
No, I just have the turbo nothing else on it.
post #7 of 26 (permalink) Old 09-30-2009, 07:37 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: holset turbo
According to the assembly number, it came off a volvo truck: HE431Ve - Holset - Catalog - TurboMaster
Service manual for the HE431Ve:
http://www.holset.co.uk/partsservice...Data_Sheet.pdf
According to here: HOLSET HE431VeTi Turbo it can go on '04 up Mack or Volvo trucks. Judging by the pictures, you got shorted the VGT control (valve?)
compressor map:
http://img17.imageshack.us/img17/1212/dsc00003dls.jpg
Go ARMY!
cowboy_dan is offline
post #8 of 26 (permalink) Old 09-30-2009, 08:13 PM Thread Starter
co04cobra's Avatar
Re: holset turbo
Yea im just trying to find out what it might be worth. Or if can be used/ adapted to anything else.
post #9 of 26 (permalink) Old 09-30-2009, 08:30 PM
HRT Performance
HotRodTractor's Avatar
Re: holset turbo
I just saw one of those bolted to a 12V not too long ago...... Damn thing had more whistle at idle than a 6 OhNo! Not sure if he ever got it dialed in and working quite right though.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #10 of 26 (permalink) Old 09-30-2009, 09:20 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: holset turbo
The max airflow according to that map is about 80 lb/min, which is about 20lb/min more than the GTP38, and 10 lb/min more than the GTP38R and H2E. Max air flow is comparable to a GT42, 94mm in 56 trim.
Low end appears to be comparable to the H2e.
But, the max PR (~4.6-4.7) is more than any of those other turbos except eh H2E. Even the GT42 needs to be about 100mm before it can reach above a PR of 4.0
It might be an interesting project to try to put on on a 7.3.
Go ARMY!
