7.3 fuel pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-28-2009, 03:48 AM Thread Starter
7.3 fuel pressure
i put a fuel pressure gauge in my 7.3 an it keeps it peged at 60 psi should i get a dif gauge or what?
1999 ford super duty ex cab short bed 4x4 dp-tuner f-5 lomp mod,80 econ,100,120 race,140 aggresive 4inch exaust to 6-inch tip non-wastegated housing upgrade from bts di-performance crossover line di-performance fuel tank mixing delete autometer gauges boost,trans,pyro custom made cold air intake.
big bad stroker is offline
post #2 of 9 (permalink) Old 09-28-2009, 03:54 AM
Re: 7.3 fuel pressure
my obs at idle for fuel pressure is 60psi
02 f250
countryboyrob is offline
post #3 of 9 (permalink) Old 09-28-2009, 04:08 AM
Lee
Lee's Avatar
Should be around 80 before the regulator and 65 after.
01 F250 Qssb Turbo, Adrenaline, Tymar Intake, PHP tuning,4" Exh, Suncoast trans,7635 lb
Lee is offline
post #4 of 9 (permalink) Old 09-28-2009, 06:41 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Sounds normal... What are you wanting to see?
Joe
CSIPSD is offline
post #5 of 9 (permalink) Old 09-28-2009, 07:39 PM
NorCalDiesel's Avatar
pegged as in it only goes to 60psi? if so you should get a fuel psi gauge that goes to 100psi. 60psi is normal for a stock fuel pump, but you could get it to about 65psi.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #6 of 9 (permalink) Old 09-28-2009, 07:47 PM
HRT Performance
HotRodTractor's Avatar
Come again?
The factory system as well as most of the regulated returns keep 65psi before the regulator and dump off excess volume to maintain that pressure and send it back to the tank. Just where is the system at 80psi and how long do you think your electric pump can maintain 80psi?
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 9 (permalink) Old 09-29-2009, 04:33 AM
Lee
Lee's Avatar
Ok, I should have said the pump should be capable of around 80 (dead headed) and 65 when regulated. So then a 60psi gauge would always be pegged.
Lee is offline
post #8 of 9 (permalink) Old 09-30-2009, 04:20 AM Thread Starter
my fuel system is stock an i put a gauge on it mine stays around 70 at wot it will pull down to 50 55 what should i do to make it keep its pressure?
post #9 of 9 (permalink) Old 09-30-2009, 04:24 AM
06powerstroke's Avatar
Your WOT pressure is still good, I wouldn't worry about it.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
