Tune H.P. question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-26-2009, 01:16 AM Thread Starter
CGMKCM's Avatar
Tune H.P. question
Just recieved my Oct. Diesel World and I read the article about the TS 6 pos chip and the dyno results.
How are the HP ratings determined?
For example, on the 140 HP setting the truck made 74 hp more than stock. Why is it a 140 HP setting?
Is this a set standard or do the tuners decide what to label the settings?
On the 6.4 tunes are the numbers accurate?
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #2 of 13 (permalink) Old 09-26-2009, 01:25 AM
Re: Tune H.P. question
the truck did not have the supporting mods like a fuel system, turbo or injectors to get the full benefit of the 140 tune in fact it probally made more power on one of the lower settings
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #3 of 13 (permalink) Old 09-26-2009, 02:08 AM Thread Starter
CGMKCM's Avatar
You are correct, the truck made as much horsepower on the 50 HP setting as on the 140 HP setting.
So tune HP ratings are potential output over stock?
Are all of the stock injectored guys running tunes >100 HP just wasting there money?
[SIGPIC][/SIGPIC]
BTS Tranny
PHP Phoenix chip
Adrenalin
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #4 of 13 (permalink) Old 09-26-2009, 02:19 AM
It is 140 HP up where there is a factory fuel limit above 3200 RPMs....
mattr66 is offline
post #5 of 13 (permalink) Old 09-26-2009, 02:42 AM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Matt? Please elaborate.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #6 of 13 (permalink) Old 09-26-2009, 02:50 AM Thread Starter
CGMKCM's Avatar
[SIGPIC][/SIGPIC]
BTS Tranny
PHP Phoenix chip
Adrenalin
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #7 of 13 (permalink) Old 09-26-2009, 02:59 AM
If you look at power output somewhere around 3300 or so you can see where the factory fuel cut starts kicking in. If you compare power up there then you might have another 100 or so.
mattr66 is offline
post #8 of 13 (permalink) Old 09-26-2009, 03:18 AM
Garage
When?
A Chip? Programming?
Centxdiesel
post #9 of 13 (permalink) Old 09-26-2009, 04:05 AM
PHPDiesel's Avatar
Here's what Matt is talking about. The factory cuts fuel at around 3200 RPM. A lot of aftermarket programming ("custom" or not) will extend the rev limit by a couple hundred RPM.
Cody
PHPDiesel is offline
post #10 of 13 (permalink) Old 09-26-2009, 04:09 AM
secondarychaos's Avatar
Basically, you get 140 when you rev the engine above the rev limiter because at that rpm you typically won't get more than a few hp .
as far as i'm concerned, a "140" tune is an arbitrary number. an intake/exhaust/tune AD injector truck will typically do 280-300.
toss on an oil system, fuel system, and a better turbo... maybe you'll have 320-330. maybe.
On the 6.4 however, the numbers are pretty close... like 597 fuel only on a tune and few other (small) mods. that's pretty close to the advertised 300 over stock.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
