Newbie Turbo Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-25-2009, 09:50 PM Thread Starter
mbg75's Avatar
Could anyone explain the peformance differences between these 3 turbo set-ups?
Stock turbo with 1.0 turbine and ATS comp housing.
Van turbo with ATS comp housing
GTP38r
At most i might put mild injectors in at some point. trying to keep it mild since it's a PMR motor.
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
post #2 of 13 (permalink) Old 09-25-2009, 11:11 PM
Re: Newbie Turbo Questions
Stock turbo with 1.0 turbine and ATS comp housing. Larger exhaust housing for less backpressure. ATS ported compressor housing to stop surge.
Van turbo with ATS comp housing. Van turbo has non wastedgated 1.15 exhaust housing for less backpressure. ATS ported compressor housing to stop surge.
GTP38r. Ball bearing center section, larger 1.0 exhaust housing, larger compressor wheel, ported compressor housing.
I answered your questions.
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
outlaw5.0 is offline
post #3 of 13 (permalink) Old 09-25-2009, 11:14 PM Thread Starter
mbg75's Avatar
Is there a big difference in power between the three?
mbg75 is offline
post #4 of 13 (permalink) Old 09-25-2009, 11:34 PM
38r will flow more cfm with less boost comes with a 1.00 exhaust housing the van turbo has a larger exhaust wheel and a 1.15 exhaust hoursing ats housing doesnt do anything but eleminate surge no power to be added
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #5 of 13 (permalink) Old 09-25-2009, 11:35 PM
also the 38r is ball bearing and will support up to 40 psi of boost
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
post #6 of 13 (permalink) Old 09-25-2009, 11:38 PM
jkidd_39's Avatar
Yes.. and a large price difference..
1.0 ex housing - $200-250 + $80 rebuild.. It flows well but with a chip you will run out of steam pretty quick.
Van Turbo - $400-600.. Flow more Air. Lower EGT's.. Mine is a bit smokey if I bog down.. it will billow smoke..
38R - $1500. Flows lotsa air and has the option to hit 475-500HP with supporting fuel and injection mods.. Does not smoke alot w/ proper tuning. The downside of this turbo is that it is pricey.
These turbos are great turbos for DD and people that do not plan on injector upgrades.
I may catch some crap for saying it but I am happy with my truck b/c it is a work truck. If I wanted to play and really get some nice numbers I would get the 38R.. but the sticker shock was too much for me.
And I got my van turbo w/ a ceramic coated exhaust housing for $430
Got any questions throw them out or PM me.
Good luck.
Andrew
2002 F-350 CCLB 7.3 250,000 Miles *** 5" MKO Power Exhaust, 6637, Foil Delete, DB's HT Starter, EV2 Gauges, 6.0 IC/TC, Van Turbo, WW, Casserly Stg. 1 Singles, BTS VB, DP Tuner, HPX***
2008 F-450 CCDRW 80k ***4"DP-5"MBRP, S&B Intake, Elite EGR delete w/ wastegate, Elite Studs, DPF/DOC delete, KEM 345***
jkidd_39 is offline
post #7 of 13 (permalink) Old 09-25-2009, 11:50 PM
but the 38r will out last the other 2
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
post #8 of 13 (permalink) Old 09-25-2009, 11:57 PM
jkidd_39's Avatar
I don't know about outlast. I've never blown a stock turbo up and we have been hauling heavy for almost a million miles on 3 trucks (combined miles)
I would say that a 38R would make the truck drive much nicer.
Now that I have my van turbo I am very happy. However if I did it again I would prob save up and go 38R.
To the OP.. a set of stage I injectors. (stock nozzles) and a 38R would be nice and you would be at 350-400hp w/ good tuning.
jkidd_39 is offline
post #9 of 13 (permalink) Old 09-25-2009, 11:59 PM
my stock turbo blew up at 178000 miles my buddy blew 3 up before he hit 100000 and my other buddies truck ate 2 stockes one a 100k and 150k
just a thought
Dyno proven tuning
suncoast tranny
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
post #10 of 13 (permalink) Old 09-26-2009, 04:51 AM
PHPDiesel's Avatar
just a thought
Those probably weren't "stock programming" and "light right foot" miles though.
Cody
PHPDiesel is offline
