Fuel line sizes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-02-2015, 11:26 AM Thread Starter
Carolina444's Avatar
Fuel line sizes
My factory pump is getting week (dropping 10-12psi @WOT) I was wanting to build a dual Bosch system and I was wondering if the 3/8" pickup and feed line I'm running will be large enough? Guess I'm being lazy and don't want to drop the tank again to upgrade the pickup and lines.
E99 f250 2wd cclb,257k, tymar intake, stock turbo w/ riffraff billet wheel, PIS 230/100,regulated return, hbjr, pmt1, hydra w/dynoproven and powerstruck tunes, 140v Idm, 4" exhuast, isspro's, ccv, ebpv delete, jwvb w/6.0 cooler
Coming soon: BASB
Carolina444 is offline
post #2 of 10 (permalink) Old 03-02-2015, 01:08 PM
Banned
Re: Fuel line sizes
Depends how hot the tune is I'm sure you would see a few psi drop bit I would not know I went strait to all 5/8 line
97 psd big red is offline
post #3 of 10 (permalink) Old 03-02-2015, 01:16 PM Thread Starter
Re: Fuel line sizes
Guess I can try it and see.. But I did read on Strickly FAQ page that the recommend 5/8 so I guess I need to get off my ass and drop the tank
Coming soon: BASB
post #4 of 10 (permalink) Old 03-02-2015, 01:22 PM
Banned
Re: Fuel line sizes
Fwiw my auto parts store show three different brands of replacement pumps I did the research two of them flow 50gph and the one only 35 gph
post #5 of 10 (permalink) Old 03-02-2015, 09:54 PM
Re: Fuel line sizes
Your gonna want to run minimum 1/2 suction line to those pumps. Preferbilly 5/8.
3/8 is fine for the feed.
If your suction line is too small your gonna burn up those new pumps. It will cavitate
swaan is offline
post #6 of 10 (permalink) Old 03-03-2015, 08:08 AM
Banned
Re: Fuel line sizes
With 238/100 you might and I say might get away with one pump I would try one of the 50 gph pumps and see it can't hurt anything if bit is not enough then add another pump in.
post #7 of 10 (permalink) Old 03-03-2015, 06:48 PM
All done now
Arisley's Avatar
Re: Fuel line sizes
Stocker flows 60 GPH. I would run 5/8 from the tank to the motor. And 1/2 inch from the motor back to the tank.
Arisley is offline
post #8 of 10 (permalink) Old 03-03-2015, 10:57 PM Thread Starter
Re: Fuel line sizes
Everything I read suggests going 5/8 from the tank to pump(s) so that's what I'm going to do.
Coming soon: BASB
post #9 of 10 (permalink) Old 03-03-2015, 11:00 PM Thread Starter
Re: Fuel line sizes
Are you talking like a Bosch 044? I read people using them but didn't find much on how long they are lasting
Coming soon: BASB
post #10 of 10 (permalink) Old 03-04-2015, 02:52 AM
Re: Fuel line sizes
Yes , that's why I said min 1/2 but preferbilly 5/8.
I run 1/2 from a sump to my fuelab. Works fine. But if I was to use a draw straw from top of tank, 5/8 would be better.
swaan is offline
