Regulated Return Fuel System - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 89 (permalink) Old 09-22-2009, 06:04 AM Thread Starter
MacAssassin
I'm in the market for a after market fuel system and wondering what people suggest. What is the most bang for the buck and reliable. I want to do the complete system from tank to heads any suggestions would be great.
2002 F-250 4x4 CCSB+, BTS Trans, Gtp38r turbo,Non EBPV pedistal, Bellowed ceramic coated uppipes, Rosewood AA single shot 180cc injectors, Tony wildman tunes, 4" turbo back exhaust, Tymar intake, zoodad mod,AIH delete, 315/75/16 tires, 3.73 gears.
2000 Ford F-250 XCLB- stock (just bought)
MacAssassin is offline
post #2 of 89 (permalink) Old 09-22-2009, 06:46 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Re: Regulated Return Fuel System
Build it yourself, if you are able to do so.. And the Fuel Lab pump is the only option for the pump...
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #3 of 89 (permalink) Old 09-22-2009, 01:14 PM
Custom Trailer Sales
TrailerHauler's Avatar
If you wanted something assembled ITP has a quality kit.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #4 of 89 (permalink) Old 09-22-2009, 02:05 PM
PSDfan99's Avatar
ITP Diesel's regulated return was 100% perfect fit and finish. Awesome kit, it went right together and I never had any clearance issues assembling it or anything. Well worth the money!
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #5 of 89 (permalink) Old 09-22-2009, 02:14 PM
A Ghost these days...
farm boy's Avatar
Sorry, too lazy to re-post all the pictures.
Installed my Homemade RR this weekend!!! - Powerstroke Nation
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #6 of 89 (permalink) Old 09-22-2009, 02:21 PM
Milk Truck
abianca99's Avatar
DIY imo
99.5 F250 cclb 4x4...modded, but looks stock
abianca99 is offline
post #7 of 89 (permalink) Old 09-22-2009, 04:01 PM
im going to build my own also. looks like you have the fuel bowl deleted.. where did you get your fuel line and what size.. Do you have a parts list you could pm me??
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #8 of 89 (permalink) Old 09-22-2009, 04:19 PM
and were do i get the walboro fuel pump?? and what size is it??
post #9 of 89 (permalink) Old 09-22-2009, 04:22 PM
farm boy's Avatar
I ordered my fuel line and fittings from JEGS and Summit Racing online. All my info is on the attached sheet.
farm boy is offline
post #10 of 89 (permalink) Old 09-22-2009, 05:59 PM
Send a message via AIM to JohnT
For the tank to the Regulated Return, if you want something that is all out do this. Get the ITP 5/8" pickup, and the fuel lab pump he also sells. If you can't wiring up a relay, then also buy his wiring kit(or if you want a nice wiring kit just buy the one ITP sells, you have to call for it).
Run 5/8"(10an) line from the pickup to a 10micron filter/water seperator. Then 5/8" line from the filter to the pump, then(I am not sure what the output of the fuel lab pump is so I am assuming here)1/2" line from the pump to a 2 micron filter, then from the 2 micron filter to the Y block in the Regulated Return. Hopefully someone will chime in with the filter base and filter numbers because I don't know them. I used a Dahl 150 pre pump, and did not have one post pump(not recommened if you don't have the factory filter in place!!).
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
