in line fuel filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-21-2009, 12:55 AM Thread Starter
in line fuel filter
Anybody done this or something similar to this on a 7.3????
[URL="http://www.rocketcityrockcrawlers.com/memberstuff/al/PPF_2008-02-25.pdf"
Well couldnt figure out how to post the link...
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #2 of 8 (permalink) Old 09-21-2009, 12:58 AM
Super Hauler!
Super_Hauler's Avatar
Re: in line fuel filter
link no worky
Super_Hauler is offline
post #3 of 8 (permalink) Old 09-21-2009, 01:10 AM Thread Starter
http://www.rocketcityrockcrawlers.co...2008-02-25.pdf
post #4 of 8 (permalink) Old 09-21-2009, 01:22 AM
Kid with a Wrench
AlaskaRedneK's Avatar
Send a message via MSN to AlaskaRedneK
That pfd was hard for me to follow.... So he added an inline filter between his aux tank and oem?
-Matt
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, Fresh Engine, Stacks, 7 Gauges, AFE, e-fan, BIG Kustom fuel system, 250cc
Hybrids w/ 100%s, H2E, 3" intakes, Bad Boy
Tranny built by me, ARPs, 910s, P-rods, 17*, SD IC
AlaskaRedneK is offline
post #5 of 8 (permalink) Old 09-21-2009, 04:48 AM Thread Starter
yes he did.. and changed his fuel lines also to the oem filter.. just wondering if anybody had done something similar to the 7.3???
post #6 of 8 (permalink) Old 09-21-2009, 01:32 PM
I had an aux tank that gravity fed into my stock tank on my last truck. I put an inline filter between the two as the aux tank had some rust in it.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #7 of 8 (permalink) Old 09-22-2009, 01:36 PM
This is known as the pre-pump mod, here are more discussion of it on this site: https://powerstrokenation.com/forums/...archid=1746749
It's pretty easy to do whether it's a 7.3 or 6.0 since I've done both. The difference between the 7.3 and 6.0 is the 7.3 pump vs. the 6.0's HFCM, but the fuel line connections are the same. Both of us replaced the fuel line from the tank and to the pre-pump filter to the pump/HFCM to get rid of the quick disconnects that can leak air under vacuum.
Here's a ready made kit from ITP Diesel for the 7.3: http://www.itpdiesel.com/store.php/products/73L_TankKit; it will fit the 6.0 too, but you won't need the Hutch mod stuff for the 6.0.
The hard part is taking down the tank, once you do that, it's just plumbing plus a little mechanical installation for the filter head.
If you're having trouble following the .pdf, just ask. The confusion might be that I have four fuel filters on my truck, one between the aux fuel tank and the OEM fuel tank, one between the tank and the HFCM/pump plus the two OEM fuel filters. Clear as mud?
Hope this helps.
Al
FTG-05 is offline
post #8 of 8 (permalink) Old 09-22-2009, 02:52 PM Thread Starter
well thats what im looking at.. was wondering about replacing my fuel line and going to the bigger size 3/8.. benefit or waste of time??
