Obs 7.3 with air dog 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-16-2015, 02:18 AM Thread Starter
I have an air dog 2 I want to put on an obs 7.3 I seen a post on here with a guy who used a 4 port distribution block going to each corner port of the motor. if someone could give me a parts list and step by step, possibly some pictures of how this was done it would be greatly appreciated
I am new to this forum but have read many posts on here, great forum
Nicmeister95 is offline
post #2 of 12 (permalink) Old 02-16-2015, 11:40 AM
m j
m j's Avatar
Re: Obs 7.3 with air dog 2
not the pump you want to use on an OBS
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #3 of 12 (permalink) Old 02-16-2015, 11:46 AM
OBSpstroke97's Avatar
Agreed ^ go with Bosch sd pump(s), A1000, fuel lab, ect.
1997 F-250, D60, 8in lift/38s, OUO ladder bars, BTS, Spearco 6.0 IC, SRP 1.1, Irate 468 turbo, Dyno proven tunes, P.I.S 300/200s, ARPs/910s/Smith bros push rods, A1000/sump.
[email protected] on 38s
OBSpstroke97 is offline
post #4 of 12 (permalink) Old 02-17-2015, 10:24 PM Thread Starter
I already have the pump. So I'd like to use it
post #5 of 12 (permalink) Old 02-18-2015, 04:10 AM
m j
m j's Avatar
can the pump reliably deliver 60+ psi?
can you move the regulator to a position after the motor is fed?
the airdog serves no purpose on the ford fuel system
m j is offline
post #6 of 12 (permalink) Old 02-22-2015, 02:00 AM Thread Starter
Supposedly they can. I have read forums where they are used so not to be rude but please just give advice on how to use this pump
post #7 of 12 (permalink) Old 02-22-2015, 02:24 AM
Banned
Correct me if I'm wrong the pump has regulator attached to it right?
I have no clue I've never seen one but from what mj said I will assume it is if that is the case could you use the pump still yes I would think that you could open the regulator that's attached to the pump wide open then still add a regulator on the return cost more money and makes no since but I balive it could be done like that. Rember I'm only assuming the regulator is attached to the pump.
I could be totally wrong I have no clue
97 psd big red is offline
post #8 of 12 (permalink) Old 02-22-2015, 07:46 AM
Terminator Nation
Regulator is integral to pump. With a 7.3 application the regulator is just cranked wide open since its useless. Still need to have a regulator on the fuel return side of the Ford fuel system.
And if you want a fuel preperporator (Airdog's fancy word for a deaerator), you can build your own. Most guys don't bother.
Best thing is sell it to a Dodge guy and use a conventional setup for a 7.3. You probably would make money.
old man dave is offline
post #9 of 12 (permalink) Old 02-22-2015, 10:00 PM
I use my airdog to feed my stock pump. It is there as a prepump filter and to remove air from the system. I believe there are two types of airdogs. There is the one that you can replace your stock pump and the one that I have which is to supplement the stock pump and I believes pumps at about 10 psi to the stock pump.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #10 of 12 (permalink) Old 02-23-2015, 12:15 PM
Banned
So like I had assumed he could use it just seems like a lot of work.
