Nitrous Question?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-16-2009, 06:52 PM Thread Starter
theSLEEPER's Avatar
Nitrous Question??
If I got this, would I be able to use it on my PSD with a little innovation? I seem to remember somewhere I saw that they used the wet nozzles as a two stage deal?
NOS 07006 NOS Sniper Universal EFI Wet Kit
theSLEEPER is offline
post #2 of 14 (permalink) Old 09-16-2009, 06:53 PM
Busy Busy
Marty's Avatar
Re: Nitrous Question??
What would YOU use this on your truck for? LMAO.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 14 (permalink) Old 09-16-2009, 06:55 PM Thread Starter
theSLEEPER's Avatar
Fag. It'd be for in the future. But WOULD it work. Lets wait for just a minute before the smack begins.
post #4 of 14 (permalink) Old 09-16-2009, 06:59 PM
The Sniper kit has a fuel and nitrous solenoids. You would need a second nitous solenoid to make a 2 stage.
I used the 5.0 mustang dry setup because it uses 2 solenoids to start with and you only need 1 hose and another dry nozzle. The solenoids are small and only support like a .075 jet each (I think) though.... that should be plenty.
mattr66 is offline
post #5 of 14 (permalink) Old 09-16-2009, 07:00 PM Thread Starter
theSLEEPER's Avatar
The reason I'm asking is because a guy offered to trade me that kit for my old tires. And I'm willing to do it if I could use it...
post #6 of 14 (permalink) Old 09-16-2009, 07:04 PM
you could use it but you would need a second nitrous solenoid to make it into a 2 stage dry system. The fuel solenoid is made differently to hold lower pressures. So for less than another 100 dollars you could make it work.
I put my first stage off a micro switch on the fuel pedal that activates at WOT and then arms a second stage that kicks on at 30lbs of boost. That way you can control your nitrous off the line and then get the second stage kicking in once you are rolling.
mattr66 is offline
post #7 of 14 (permalink) Old 09-16-2009, 07:09 PM Thread Starter
theSLEEPER's Avatar
That's what I was thinking. Thanks Matt! So I'd have to get a solenoid and a WOT switch and do some different wiring. Cool!
post #8 of 14 (permalink) Old 09-16-2009, 07:11 PM
Yes.... I welded a bracked to my throttle pedal assembly for the microswitch.
Everything is armed with a master swicth and you have to be armed and at wot for stage 1 and armed, at wot, and 30lbs of boost for stage 2 to work.
Pretty easy to visualize using ladder logic.
mattr66 is offline
post #9 of 14 (permalink) Old 09-16-2009, 07:20 PM Thread Starter
theSLEEPER's Avatar
No doubt. I've figured it a few times how I would run it. The 30psi switch wouldn't be bad, especially for consistency. But I might just run a trigger for until it hooks well.
post #10 of 14 (permalink) Old 09-16-2009, 09:10 PM
Back in Black
stroken's Avatar
NOS. makes a diesel NOS kit.
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
