Is there something wrong with my turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-16-2009, 06:29 AM Thread Starter
thecabinetguy's Avatar
I put on a 6637 mod the filter is crammed in pretty tight. When I'm making a long trip pulling a trailer the check engine light comes on if I pull over and idle and shut the truck off when I restart the check engine light is off. could the filter be sucking hot engine air a heating the turbo???
Darrell
2003 F250 Lariat crew cab
Swamps stage one injectors
BTS transmission
6637 filter
310000 miles and going strong (sometimes)
thecabinetguy is offline
post #2 of 8 (permalink) Old 09-16-2009, 07:11 AM
krankin's Avatar
Re: Is there something wrong with my turbo
It shouldn't matter if the filter is sucking hot air. The turbo is already a lot hotter than the air it is pulling in. What kind of driving sets the check engine light? Is it hard acceleration or pulling hills? If you have access to a code reader, pull the codes and post them and we will be able to help you out
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
krankin is offline
post #3 of 8 (permalink) Old 09-16-2009, 08:46 AM
fear no poser
how much boos do u push and is their any other mods
cumminskiller is offline
post #4 of 8 (permalink) Old 09-16-2009, 02:42 PM
theSLEEPER's Avatar
Are you tuned? I know under hard acceleration, my truck throws a light that usually means ICP. Before I had a fooler, it would throw an overboost code.
theSLEEPER is offline
post #5 of 8 (permalink) Old 09-16-2009, 03:46 PM
TRX370r's Avatar
What did you do with air intake temp sensor when you put the 6637 on? That could be your code.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #6 of 8 (permalink) Old 09-16-2009, 06:17 PM Thread Starter
I dont know if thier is a tuner I bought the truck used at auction is thier any way to find out. I think the air intake temp sensor is laying on the wheel well?
Darrell
BTS transmission
6637 filter
post #7 of 8 (permalink) Old 09-16-2009, 06:18 PM Thread Starter
I will pull the codes and get back
Darrell
BTS transmission
6637 filter
post #8 of 8 (permalink) Old 09-17-2009, 01:15 AM
Village Idiot
southmike's Avatar
have to start there..could be many diff things
southmike is offline
