Any benefit to coating and wrapping up pipes? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-16-2009, 04:08 AM Thread Starter
I am thinking about wrapping my DP, and started thinking about wrapping the up pipes also.
I'm not sure if this would benefit, or if it would just warp the up pipes.
Any ideas?
99 F350 CCLB
skav is offline
post #2 of 14 (permalink) Old 09-16-2009, 07:06 AM
krankin's Avatar
Re: Any benefit to coating and wrapping up pipes?
The wrap would hold the heat in the material of the up-pipes, which would warp and destroy them after a while. When they are ceramic coated, they are coated on the inside of the pipe, so the heat doesn't saturate the pipe material.
IIRC, down pipes are fine to wrap though
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
krankin is offline
post #3 of 14 (permalink) Old 09-16-2009, 07:47 AM
Crazy Redneck
UNCOOL's Avatar
Like this?
http://farm4.static.flickr.com/3355/...8a6fc874_m.jpg
My pipes have been wrapped for more than 3 years with NO leaks, cracks or warping.
UNCOOL is offline
post #4 of 14 (permalink) Old 09-16-2009, 12:31 PM
moore20017.3's Avatar
This is a good topic.
Insulation (heat wrap) is kind of a double edged sword to me. It keeps the exhaust from cooling too rapidly (which will warp worse than the heat itself) but in the case of extended high heat situations the heat will not radiate out of the pipe and the temp may get too high causing damage to the pipe.
I would get them ceramic coated along with the turbine and downpipe.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #5 of 14 (permalink) Old 09-16-2009, 02:05 PM
Banned
Any ideas?
One definite benefit would be the opportunity to R&R them rather quickly when they fail.
Charles is offline
post #6 of 14 (permalink) Old 09-16-2009, 02:11 PM
theSLEEPER's Avatar
Why's that? Rust?
theSLEEPER is offline
post #7 of 14 (permalink) Old 09-16-2009, 02:12 PM
Banned
Originally Posted by UNCOOL View Post
Like this?
If your truck produced the kind of heat cycles in those three years to match what most trucks do in a month you'd be singing a different tune. I can assure you, that a wrapped setup with no expansion bellows like that wouldn't last 3 weeks on my truck. If the pipes didn't crush, it would push my manifolds off the head and shear manifold bolts. You have any manifold leaks?
The fact that it didn't fail proves little. Non-wrapped they would be more robust for sure. Yet while it's a fact that they are more prone to failure wrapped, I would bet you couldn't show any valid evidence to prove the wrap actually even helped anything.
Charles is offline
post #8 of 14 (permalink) Old 09-16-2009, 05:12 PM
Don't wrap anything...RUST!!! you should see what it did to my EB exhaust system!
email:
Website:
OBSWIZ is offline
post #9 of 14 (permalink) Old 11-14-2009, 09:33 PM
edge186's Avatar
i just discovered that my up pipes are leaking and am looking into a new set. so no that i know not to wrap them, is ceramic coating recommended or not necessary? they are coated on the inside, correct?
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #10 of 14 (permalink) Old 11-14-2009, 09:53 PM
Super Hauler!
Super_Hauler's Avatar
If you can afford the DI uppipes from dave i would go that route. They are awesome. I had a really bad exhaust leak from the donuts on the stocker and DI fixed it right up!
Diesel Innovations - Products
Super_Hauler is offline
