Regulated return and remote IPR for the HPO system? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-16-2009, 01:07 AM Thread Starter
So I was thinking about the remote IPR setup on twin pumps, (and the stock pump now that I think about it) and how it is plumbed straight off the pumps.
Then I started thinking about how the flow through design of the regulated return on the fuel system works better than the stock setup.
Here is my question...
Would there be any benefit to removing/ blocking the IPR from the pump, Feeding the heads from the front ports w the stock feed lines, then using a return line from the back of each head to a block w 1 or 2 IPRs, then dumping back down the front cover to the crank case?
How would using a setup like this affect the pump/s and injectors?
Would this type of IPR return provide better flow and more consistent pressure to the HPO system?
I know that many times a HPOX line smooths the idle and balances the system. This would basically do the same thing by connecting both heads to the remote IPR block.
I would like to hear thoughts on this concept from others that have more knowledge on the HPOP system then I do.
99 F350 CCLB
skav is offline
post #2 of 12 (permalink) Old 09-16-2009, 02:02 AM
What else?
smokyred's Avatar
Re: Regulated return and remote IPR for the HPO system?
Sounds like a good idea.
Let's see if Jason aka HotRodTractor sees this and what he thinks.
Dave
smokyred is offline
post #3 of 12 (permalink) Old 09-16-2009, 03:46 AM Thread Starter
I'd ask the guys at Swamps to chime in, but all they can think about lately is CR.
How about Charles, or one of the others w a solid grasp on the subject.
99 F350 CCLB
skav is offline
post #4 of 12 (permalink) Old 09-16-2009, 03:48 AM Thread Starter
Dave
Jason should comment also!
Bunch of slackers! Get on w it. Tell me why or why not.
99 F350 CCLB
skav is offline
post #5 of 12 (permalink) Old 09-16-2009, 02:54 PM Thread Starter
I thought that this would be an interesting topic. Nobody has anything to say about it?
Oh well. Guess I should go yo work.
99 F350 CCLB
skav is offline
post #6 of 12 (permalink) Old 09-16-2009, 04:18 PM
I've had a few ideas on the subject.... sorry for not chiming in sooner.
mattr66 is offline
post #7 of 12 (permalink) Old 09-16-2009, 04:26 PM
HRT Performance
HotRodTractor's Avatar
Huh - sounds exactly like a part that I have had in my possession for some time - in fact its already went through a couple revisions fine tuning it. Several people have seen it at TS and at Unlimited's dyno day. I also have one sitting in the shop to install on another truck after I complete some other testing and modification to said truck.
I'll see if I can post up pictures. I know I have one installed of the prototype - and I can get one of the production part.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #8 of 12 (permalink) Old 09-16-2009, 06:37 PM Thread Starter
I like the idea. It would purge the air from the system quicker, and allow 2 IPRs as well as an external cooler to eliminate EOT issues that some have experienced while using modified/ twin pump setups.
99 F350 CCLB
skav is offline
post #9 of 12 (permalink) Old 09-16-2009, 07:15 PM
HRT Performance
Here is a pic of the prototype installed. The new ones are smaller and slightly different.
2015 VW Jetta TDI
2006 VW Jetta TDI
post #10 of 12 (permalink) Old 09-16-2009, 07:18 PM
I like your logo......
mattr66 is offline
