Foil delete...wanna re-wrap it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-15-2009, 05:30 AM Thread Starter
Well, after doing mods to make the 7.3 noisier, I'm getting tired of it. With the delete pipe, foil mod, open intake, it's all a bit too much. And quite frankly, after dumping $4k into my audio system, I want it as quiet as possible inside. I have a top notch system and I'd like to enjoy it.
So, can I re-wrap my cac tube with 2" header wrap to quiet it down a little? Any harm in this?
2001 Excursion Limited, Swamps 175/146 singles, John Wood tranny, UltraLite Gauges, 4" turbo back, AFE stage 1, Dp tunes, 7" Superlift, Fox Shocks, Firestone Airbags, 35"Toyo M/t...blah,blah,blah
SmokeWagon is offline
post #2 of 15 (permalink) Old 09-15-2009, 05:45 AM
Layson's Avatar
Re: Foil delete...wanna re-wrap it
Not going to hurt a thing... I think changing the intake will yield the most results... Or some sound deadening... That will go a long way...
Layson is offline
post #3 of 15 (permalink) Old 09-15-2009, 05:54 AM
FordCowboy's Avatar
You could always go buy a Prius. JK. The noise can be a pain sometimes. I don't know how much the wrap will help, compared to the intake and exhaust but then you lose performance.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #4 of 15 (permalink) Old 09-15-2009, 06:15 AM
Starting Over
kainers's Avatar
Wear long sleeve shirt that Header wrap will make you itch like a SOB.
Never did it for noise but I wrapped the CAC pipes.What a waste for what I was trying to attempt.
You want a quiet truck buy a 6.4
kainers is offline
post #5 of 15 (permalink) Old 09-15-2009, 07:45 AM
Senior Member
HPAddict's Avatar
Header wrap is for heat, not noise. If you spent $4000 on a system, another $300 in dynamat is going to be no problem. Pm unbroken if you have questions. He said he put like 250 square feet of it in his truck
HPAddict is offline
post #6 of 15 (permalink) Old 09-15-2009, 09:31 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
{95 F250 Powerstroke XLT} 5 spd, injectors by Farmers Diesel, tunes by tyrant diesel, AFE stage 2 intake, custom intercooler, 3" down pipe to custom 5in stack. EBPV break, custom electric fuel system, IDM mod by mattymx, CCV mod, D60 with F-Superduty springs, diprocol EGT, Boost and Fuel PSI guages.
joebob3093 is offline
post #7 of 15 (permalink) Old 09-15-2009, 01:27 PM Thread Starter
Already there my friend. All 4 doors, entire floor pan and rear barn doors have 2 layers of Raamat with 1/2" closed cell foam over that. I think maybe some of my leftover sound deadening may work better.
Thanks for the suggestions.
post #8 of 15 (permalink) Old 09-15-2009, 01:29 PM
theSLEEPER's Avatar
I'll send you a wrapped pipe for an unwrapped. You pay shipping both ways.
theSLEEPER is offline
post #9 of 15 (permalink) Old 09-15-2009, 03:40 PM
Senior Member
HPAddict's Avatar
dynamat the hood and the firewall?
HPAddict is offline
post #10 of 15 (permalink) Old 09-15-2009, 03:44 PM
OBS junkie
Cat_Rebel's Avatar
What about trying a 6637 filter instead of the AFE stage 1?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
