what do i do with my turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-15-2009, 02:16 AM Thread Starter
I have a e99 with 156k. I put glow plugs in the other day and when i checked the turbo I could feel a small amount of play in the compressor wheel and the intercooler tubes had some oil in them. I dont have money for a new turbo so i was going to rebuild and maybe upgrade housing/wheel/ van turbo. I have 6pos chip and 5in down pipe. what do ya think
99 powerstroke reg cab 6 speed 4in lift t+s 6 position chip 5in exhaust k+n intake and exhaust brake
post #2 of 11 (permalink) Old 09-15-2009, 02:18 AM
PSDfan99's Avatar
Re: what do i do with my turbo
Rebuild kit from Bean's Diesel is like $125 and it's easy to do. You have to pull the turbo off to rebuild it, but pulling it easy too. That'll fix the in and out play.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #3 of 11 (permalink) Old 09-15-2009, 02:28 AM Thread Starter
I would like to upgrade at the same time can i buy a new housing and or wheel to get more power
post #4 of 11 (permalink) Old 09-15-2009, 02:29 AM
Village Idiot
southmike's Avatar
What kind of exhaust brake do you have.
I would rebuild it or save for a beans d66 it the only dropin foran early99.
Not sure there are housings etc for the e99.
Beans would be the one to ask imho
southmike is offline
post #5 of 11 (permalink) Old 09-15-2009, 02:37 AM Thread Starter
sp diesel it doesnt bolt to the turbo its all electronic
post #6 of 11 (permalink) Old 09-15-2009, 02:51 AM
First off how much play does it have? A little is normal as long as its not contacting the housing. And as long as you haven't rerouted the ccv, oil in the intercooler tubes is normal.
2000 F-350 ccsb 4x4: DIY intake, 4 inch straight, Tuning by [email protected]
99 tacoma V6 5sp 4x4: Chaos/DR mid travel kit, F/R glass, 33x12.50 MTR's---Sold
08 F-150 Lariat Screw 4x4:---Sold
2005 F-250 Lariat ccsb 4x4 auto: All stock for now
Stroke00 is offline
post #7 of 11 (permalink) Old 09-15-2009, 04:53 AM
What else?
smokyred's Avatar
It will have a small amount of side to side play, but it should have no in and out play, though a little is acceptable in my book as long as it doesn't touch the comp. housing. I've killed a few so I can definately say I've got experience here, lol.
And yes, the oil in your IC tubes is normal, it comes from the CCV vent on the driver's valve cover.
Dave
smokyred is offline
post #8 of 11 (permalink) Old 09-15-2009, 10:57 PM
Village Idiot
southmike's Avatar
since you have the sp brake ...
one thing to store in your memory if you ever change turbos is
make sure you keep an ebpv pedestal.
not sure if the beans d66 does .
otherwise you will lose your exhaust break.
not sure how much play your turbo has..
is it still boosting normally , no odd noises etc.
(if it ain't broke don't fix it kinda thing)
another good source is rons turbo service on ebay.
post #9 of 11 (permalink) Old 09-16-2009, 12:21 AM
What else?
smokyred's Avatar
on Ron's turbo service, that's where I got the parts to rebuild mine when I was killing stockers.
Dave
smokyred is offline
post #10 of 11 (permalink) Old 09-16-2009, 05:29 AM
<-- GO BRONCOS
dblamp's Avatar
Niether of those will add power, they are used to get rid of turbo surge.
If you have surge, you will need one or the other, not both.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
