Sleveing a block - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-15-2009, 12:58 AM Thread Starter
cota's Avatar
Sleveing a block
Can anyone tell me what it would cost to sleve one cylinder? Thanks.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #2 of 9 (permalink) Old 09-15-2009, 01:14 AM
FordBoy86's Avatar
Re: Sleveing a block
I'm not 100% sure, a friend of mine had his 351W sleeved for 80/cyl. Hopefully someone else will chime in and give you a little bit better ball park figure
'94 F-350 4x4 DRW 5spd
Intake, DP, IDM Mod
FordBoy86 is offline
post #3 of 9 (permalink) Old 09-15-2009, 01:43 AM
Don't EFN worry about it
Aljay's Avatar
Cost me 75.00 my new motor has one sleeve.
Tuned by T Wildman
Aljay is offline
post #4 of 9 (permalink) Old 09-15-2009, 01:49 AM
Plays with Motors
Machinist's Avatar
~ $75 for one cylinder - gets cheaper per cylinder the more you do, setting up the first one is the big part.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #5 of 9 (permalink) Old 09-15-2009, 02:01 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I have been told some are asking all there rebuilt motors to be sleved at this point. Would you have any issue with that?
Joe
CSIPSD is offline
post #6 of 9 (permalink) Old 09-15-2009, 02:05 AM
01platinum's Avatar
Can't see why it would hurt.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #7 of 9 (permalink) Old 09-15-2009, 03:04 AM Thread Starter
cota's Avatar
Thanks guy's, local shop here wants way to much. I could buy a block for less than they want to sleve one. Now to find another shop.
2000,CC,4x4,auto
cota is offline
post #8 of 9 (permalink) Old 09-15-2009, 03:10 AM
Plays with Motors
Machinist's Avatar
Generally when done properly there is nothing wrong with a fully sleeved block even if it started out as a parent bore block. There needs to be the proper press setup, a good surface finish and straight/round bore to put the sleeve into...that being said, on the other hand it is common to in the process of boring to break through the parent bore at thin spots which in an street application is no problem - or even on a race motor which starts out with a thick race casting it's nothing to really worry about. My concern here would be that these blocks already have proven themselves to be weak and prone to breaking, now you cut a step at the bottom of the bores and shove a sleeve in...seems very possible that through the introduction of stress risers at these points you have effectively weakened the block. Even if cylinder wall flex was causing ring seal problems at high boost I would recommend block fill rather than a sleeve.
IMO sleeves are for repairing a damaged cylinder or bringing a rare block back to a machinable size.
2011 335i M-Sport
post #9 of 9 (permalink) Old 09-15-2009, 03:49 PM
CSIPSD's Avatar
Thank you..... Very well said.
Joe
CSIPSD is offline
