pull turbo to pull head? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-13-2009, 11:35 PM Thread Starter
TRUBBS's Avatar
do i need to pull my trubo to take the heads off my 97? what all needs to come off to get the heads off while its in the truck still. ac pump, alternator or none of it? i need to get in their to replace my head gaskets and wana know what im looking into before i dig a whole
TRUBBS is offline
post #2 of 8 (permalink) Old 09-14-2009, 12:10 AM
PSDfan99's Avatar
Re: pull turbo to pull head?
To get the heads off you need to unbolt any accessories (alternator etc) that bolt on to the head.
Pull the turbo.
Unbolt where the exhaust manifolds bolt to the uppipes.
Disconnect the UVC wiring.
Pull the injectors so you don't damage the nozzle when pulling the head off.
Disconnect the fuel lines at the heads.
Disconnect the HPOil lines at the heads.
Unbolt the heads.
I don't think I missed anything...
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #3 of 8 (permalink) Old 09-14-2009, 12:16 AM
Deputydog's Avatar
Pull the turbo.
Unbolt the heads.
Deputydog is offline
post #4 of 8 (permalink) Old 09-14-2009, 05:09 AM
urbanwheeler's Avatar
Pull the turbo.
Unbolt the heads.
The beer? you missed the "drink a beer step"
good luck
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #5 of 8 (permalink) Old 09-14-2009, 05:13 AM
OBS junkie
Cat_Rebel's Avatar
If it was my truck I'd just pull the whole motor out then you have more room to work with. Also check the rods in the cyl(s) that got any coolant in them.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 8 (permalink) Old 09-14-2009, 05:48 AM
What else?
smokyred's Avatar
You don't need to pull the turbo, but you will need to take the rockers and pushrods out, as well as the injectors.
After you get the heads off is when I would take the intake plenums and manifolds off.
Dave
smokyred is offline
post #7 of 8 (permalink) Old 09-14-2009, 07:30 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Pull the motor, I know on a superduty its a real bitch... You should really check out the cylinder that got hosed for damage.
Joe
CSIPSD is offline
post #8 of 8 (permalink) Old 09-14-2009, 08:11 PM
Layson's Avatar
It was more of a pain to pull the heads out then it was just to pull the entire motor out...
Layson is offline
