38r questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-12-2009, 10:01 PM Thread Starter
silverpsd_06's Avatar
38r questions
how far has anyone pushed the garret hp wise and how much will they take i have a six speed i was told this would be a good turbo for the 500 horse range with a quick spool but can u take them farther?? im wanting 600 or a little less thanks
2000 f-350 SRW CC, 6" lift 22" KMC wrapped in 37" Toyo's, S465, Swamps 275/226, Studs, Springs, Pushrods, Gen3, TS 6 pos chip with Swamps Tunes...
silverpsd_06 is offline
post #2 of 7 (permalink) Old 09-12-2009, 10:02 PM
Lovin the Tuna
RedSmokey's Avatar
Re: 38r questions
about 500 or a little over 500 is max they will do from what i have read... There's always a little giggle gas you could throw in
2001 F250
2000 F250
RedSmokey is offline
post #3 of 7 (permalink) Old 09-12-2009, 10:05 PM
Powerstroke Racer's Avatar
Re: 38r questions
525 is as far as we have pushed one, 600 with nos is achievable.
Powerstroke Racer is offline
post #4 of 7 (permalink) Old 09-12-2009, 10:48 PM
Re: 38r questions
But at 600 with nos how long will it last. I have not seen any excessive wear around the 500 range.
For 600+ I would think something that makes more air would be a better fit.
Muley is offline
post #5 of 7 (permalink) Old 09-13-2009, 08:26 PM Thread Starter
Re: 38r questions
so whats would be the next step up from a 38r that still has a quick spool up? isnt the 38r a drop in too? or does it require an adapter kit? i was hoping for a drop in.... any suggestions
post #6 of 7 (permalink) Old 09-13-2009, 08:30 PM
Re: 38r questions
38r is your only drop in option. You'd be suprised how much abuse a 38r can take. If you want more fuel only HP capablility you should start looking for a modded H2e or gt42 but those require different mounting kits. You also start losing streetability and towing capability if you start getting really big.
mattr66 is offline
post #7 of 7 (permalink) Old 09-14-2009, 05:56 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: 38r questions
Best towing turbo I have run thus far is a modded H2e...
Joe
CSIPSD is offline
