turbo upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-10-2009, 09:46 PM Thread Starter
turbo upgrade
ive been reading all afternoon, and i know this topic has been beat to death. but.....for all us "normal" folk who dont have engineering degrees and endless hours researching these topics, can someone point me in the right direction??? i want the next step to my puzzle, i want to upgrade the turbo on my 01 excursion. it has an edge programmer, 4" exhaust, billet convertor and thats it. i use it primarily for heading to the cottage each weekend and it usually works its ass off, running it at 135-140 kph and usually towing a trailer too!!! best truck i have ever owned.
so......what are a few choices, and keep in mind i am mechanically capable of doing the work myself
would you:
1. change the tuner? custom tuner? dp??
2. big injectors??
3. big turbo?? i have access to a 02 7.s in a van chassis for a core
4. turbo inlet pipes???
any info appreciated.
thanks in advance
ms
marksauto is offline
post #2 of 10 (permalink) Old 09-10-2009, 09:56 PM
Re: turbo upgrade
The 38r turbo is an easy drop-in upgrade. It will drop your EGTs with stock injectors and allow you to make 450+ horsepower with bigger injectors. That would be my first upgrade, then see where you EGTs are towing and then start adding fuel.
For air intakes..... My personal preference for something that doesn't try to win at the drag strip the paper filter made by Wix for the 02-03 trucks (with the 3 inch pleats has plenty of airflow for 400 HP.
mattr66 is offline
post #3 of 10 (permalink) Old 09-10-2009, 10:24 PM
Re: turbo upgrade
My experience was that the stock air box didn't seal very good, and I had all kinds of dust in the intake.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #4 of 10 (permalink) Old 09-10-2009, 10:36 PM
Re: turbo upgrade
Were you using the filter with the double foam seal?
mattr66 is offline
post #5 of 10 (permalink) Old 09-10-2009, 10:39 PM
Re: turbo upgrade
im doing the van turbo.. just got mine in today and gonna pick up a new pedestal and exhaust outlet.... id go with a new air intake also on your ex...
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #6 of 10 (permalink) Old 09-10-2009, 11:35 PM Thread Starter
Re: turbo upgrade
point me to the right direction, what is the big difference b/n p/up and van turbo??
post #7 of 10 (permalink) Old 09-10-2009, 11:42 PM
Thomas7.3psd's Avatar
Re: turbo upgrade
i would drop the edge and get tunes from matt at gearhead automotive first. then look into a diffrent turbo, custome tunes will do wonders by themselves.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #8 of 10 (permalink) Old 09-11-2009, 02:37 AM
Re: turbo upgrade
The van turbo simply gives more exhaust flow. It is a slight power upgrade, but IMO the 38r performs great with stock injectors all the way up to stage 3 hybrids. My advice is never buy something that you have to re-do when you want more power.
mattr66 is offline
post #9 of 10 (permalink) Old 09-11-2009, 01:16 PM
Re: turbo upgrade
Nope!
schmity is offline
post #10 of 10 (permalink) Old 09-11-2009, 01:30 PM
Re: turbo upgrade
I just upgraded to a van turbo. I think its great so far, I don't plan on huge amounts of hp down the road though. My hp goal is 350-400.
03_PSD is offline
