Where to draw the line on my motor please help? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 65 (permalink) Old 09-10-2009, 11:19 AM Thread Starter
hotrodtodd's Avatar
I have an early 99' that melted a cylinder some time ago and am ready to start buying parts and get underway, however this is by far the most compicated motor I have ever done in terms of choice and where to apply the $$$$ in the right places.
My goal is to tow plain and simple around 10k and am thinking 425-450 hp level.
I already have a 02' parts motor that I will be using the intake for a BD turbo thruster kit and the 17* hpop, the forged rods from the 99' new Malhe 0.030" pistons, 4'' exhaust and intake with DP f-6 tunes, boost fooler, oil cross over line and mabey water injection after its together.
With that said, here are my concerns.
#1 do I need head studs or mains, arp rod bolts?
#2 everyone says hybrid injectors but is there a cheaper alternative at that hp level?
#3 what valve springs is everyone using or stock?
#4 is stock pushrods ok or should I get a better aftermarket brand?
#5 is porting really gunna help out in this application?
#6 fuel bowl delete with regulated return, I am at that level where it will really help?
Anything else machine related that I can do aswell other than the usual machining? Mabey cement or other mods I missed?
Thanks for any advice.
hotrodtodd is offline
post #2 of 65 (permalink) Old 09-12-2009, 05:46 AM Thread Starter
hotrodtodd's Avatar
Re: Where to draw the line on my motor please help?
Can anyone chime in please?
post #3 of 65 (permalink) Old 09-12-2009, 06:00 AM
dont dick with a stock turbo, get a gt38r from a sponsor diesel innovations is a good one. 2. 200cc hybrids from full force diesel will get you your goal of 400-450, and if you have any cash left trans mods by way of valve body or torque converter will probably be needed. 3. any cash left get a regulated regulated return kit from diesel innovations also.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #4 of 65 (permalink) Old 09-12-2009, 06:08 AM
CLIFORD3's Avatar
No, but the stock bolts can only be used once!
#2 everyone says hybrid injectors but is there a cheaper alternative at that hp level?Stage 2's can hit that level but dyi would work to
#3 what valve springs is everyone using or stock? comp cams 910 but stock will work with that power level
#4 is stock pushrods ok or should I get a better aftermarket brand? stock will work but its nice not to have to worry
#5 is porting really gunna help out in this application?yes it will help in allmost any app
#6 fuel bowl delete with regulated return, I am at that level where it will really help? a rr is needed to run hybrids at wot at 100%
CLIFORD3 is offline
post #5 of 65 (permalink) Old 09-12-2009, 05:28 PM
OEM Moderator
Tom S's Avatar
Is that true for not reusing all the stock motor bolts or just head bolts?
Tom S is offline
post #6 of 65 (permalink) Old 09-12-2009, 05:35 PM
CLIFORD3's Avatar
Alot can be reused but some are one time use b/c when you torque them down they stretch.
CLIFORD3 is offline
post #7 of 65 (permalink) Old 09-12-2009, 06:37 PM
Fierro Racing
BeastPowerX10's Avatar
you would just have to look up the specs on the bolts. they can have some stretch ( its gonna happen) you would just need to make sure they are still in spec
2008 rclb Tow Rig Edition
71 Gated Deleted
Hallers Diesel Performance
Who Needs Swagger When You Got Stagger
BeastPowerX10 is offline
post #8 of 65 (permalink) Old 09-12-2009, 08:44 PM Thread Starter
hotrodtodd's Avatar
Thanks for the reply guys, I wouldnt imagine that you can measure the bolts for stretch very easy like with a caliper or mic. I know 6.0 head bolts are designed to stretch and have a one time use but isnt the 7.3 hardware if used correctly and not abused supposed to be a little more durable? I would love to use ARP internals everywhere but the price is crazy in this app so thats why I ask at 400-450hp will I be fine or iff'y.
I read that the 910's are a popular spring but is there a real difference VS stock, do stock over time loose the tension in them and the valves dont seat VS 910's?
I heard the beehive springs require some machining to get them in.
Any other machining that I should adress at the shop before its too late?
With regards to my turbo I already have the new BD one, from all the reading I could find on the GT38 vs the BD unit it stacks up pretty well and is way cheaper but if I went all out then I would go with the GT38 unit.
Trans upgrades are underway with a valve body and converter from BD.
post #9 of 65 (permalink) Old 09-12-2009, 09:07 PM
fueled by Colecovision
golfer's Avatar
Garage
you have the BD turbo?
you'll be fine with reusing stock bolts everywhere.
golfer is offline
post #10 of 65 (permalink) Old 09-12-2009, 09:12 PM Thread Starter
hotrodtodd's Avatar
Yes, its being built right now should have it in a week or two. There HQ is 20 minutes away and my buddie is a salesman there so it works out for me. Do you have any feedback on them?
