600 hp shorty build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 44 (permalink) Old 09-10-2009, 04:49 AM Thread Starter
600 hp shorty build
What's it take to make 600 hp on a early 99. I'm doing a 2wd reg cab shortbed build. It's all stock except cut down 13 " behind the wheel and cut 5" in front of the wheel and the axle moved forward 5". I'm wanting to keep the 7.3 instead of a cummins conversion. How about the p pump mechanical conversion, I would like 600 or so, I was told the manual trans was 275 h.p, so guess 325 more should do.
Rancid is offline
post #2 of 44 (permalink) Old 09-10-2009, 04:53 AM
Re: 600 hp shorty build
There are some doing it on stock bottom ends. Some say ok some say it'll blow. You'll need, oil, turbo, fuel, clutch alot more parts and alot of money. There are alot of guys on here running 600 horse power set ups. Do you have any current mods or is it bone stock?
bigjake0524 is offline
post #3 of 44 (permalink) Old 09-10-2009, 04:57 AM Thread Starter
Stock
Rancid is offline
post #4 of 44 (permalink) Old 09-10-2009, 05:20 AM
Send a message via AIM to JohnT
I wanna see pictures of this truck!
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #5 of 44 (permalink) Old 09-10-2009, 05:32 AM
If this is strictly a fun street truck, 600 is not out of reach. At minimum you need head studs, valve springs (maybe a little porting would do you some good), injectors, big oil, and a 74-76mm turbo. Since it is an early 99 you will need some small pieces off a later model truck like the intakes.
mattr66 is offline
post #6 of 44 (permalink) Old 09-10-2009, 06:24 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Give swamps a call they can hook you up
a setup basicly like mine has proven over 600 on a dyno!
I havent tryed it yet
If you still want more they are working on CR and p-pump conversions
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #7 of 44 (permalink) Old 09-10-2009, 06:37 AM
urbanwheeler's Avatar
why would you shorten the wheelbase?
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #8 of 44 (permalink) Old 09-10-2009, 01:29 PM
Banned
The wheelbase on a mustang doesn't match that of your truck for a reason. Shorter vehicles are generally faster, and more fun to drive. Not only do they weigh less, but they have improved weight transfer.
Charles is offline
post #9 of 44 (permalink) Old 09-10-2009, 01:44 PM
theSLEEPER's Avatar
I'm looking forward to your shortbed conversion!!!
To the OP...
You have a manual trans?
theSLEEPER is offline
post #10 of 44 (permalink) Old 09-10-2009, 01:51 PM
Banned
To the OP...
I already did one, on my 97.
Charles is offline
