After all this... A Cracked Block. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 107 (permalink) Old 09-10-2009, 04:30 AM Thread Starter
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Well after all I have had happen with this motor. Now the coolant in the oil can be linked to a cracked block.
This is on top of everything that has happened with this motor...
1. A set of bad injectors washed down the cyclinder walls. Requiring a rebuild.
2. Getting the engine back and having a good sized oil leak.
3. Finding out the coolant was getting into the engine oil.
4. Pulling the drivers side head off to find valve to piston contact.
5. Having Buddy pull the passenger side head off to find way worse valve contact on the passenger side.
6. Getting a second call tonight to learn that the engine block is cracked.
Realizing your motor is at EDP and will be taken care of priceless...
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #2 of 107 (permalink) Old 09-10-2009, 04:32 AM
Banning Smut
PTSUPERD's Avatar
Re: After all this... A Cracked Block.
DAYUM man. I feel your pain.
PTSUPERD is offline
post #3 of 107 (permalink) Old 09-10-2009, 04:34 AM
Deputydog's Avatar
Damn Tyler, I hate hearing all this ..
Its good knowing Buddy has it in his hands now
Deputydog is offline
post #4 of 107 (permalink) Old 09-10-2009, 04:34 AM Thread Starter
Supercharged
I forgot in the first post to explain the crack. From what I was told the crack goes from the #2 Main up to the #4 cyclinder, and on to the area around the cam shaft. I was told I was lucky I parked it when I did, and that it would of spitted parts on the ground shortly if I didn't...
I will post pics as soon as I get them..
Oil- Swamps Gen-3
Fuel - B-codes
post #5 of 107 (permalink) Old 09-10-2009, 04:35 AM
Laces Out
bigrpowr's Avatar
good dudes..if they say they got your back, they do. sleep well tonight.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #6 of 107 (permalink) Old 09-10-2009, 04:38 AM
Don't EFN worry about it
Aljay's Avatar
Sounds like my orig. OBS block cept it cracked just under the oil cooler mount rear and went to the tunnel and back down the other side. I feal your pain man my truck ran well then one day it was like a switch had been fliped.
Tuned by T Wildman
Aljay is offline
post #7 of 107 (permalink) Old 09-10-2009, 04:39 AM
Sorry to hear about all your problems. Looks like it is all getting sorted out in one way or another.
bigjake0524 is offline
post #8 of 107 (permalink) Old 09-10-2009, 04:42 AM
hotstik's Avatar
Damn! That sucks! I thought another shop just built that motor for you.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #9 of 107 (permalink) Old 09-10-2009, 04:45 AM
Banning Smut
PTSUPERD's Avatar
Buddy has your back Tyler. Its all good.
PTSUPERD is offline
post #10 of 107 (permalink) Old 09-10-2009, 04:48 AM
WHAT???
STROKIN N STYLE's Avatar
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon)
1999 F-450 cc fb 4x4 Swamped 7.3 (STOLEN)
2008 F-250 cc sb 4x4 H&S, S&B, 5", BMF, Grabbers
STROKIN N STYLE is offline
Closed Thread
