hot side map sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-10-2009, 03:22 AM Thread Starter
hot side map sensor
i was thinking the other day if you switched the map sensor pick up from the cold side of the intake to the hot side you might gain a little bottom end and throttle response. since the hot side is before the intercooler it builds more boost faster than the cold side so in theory the fuel would come on sooner than if it were on the cold side therefore build power faster not adding more just builds faster well i tryed it today and it works seems peppier on the takeoff and thoughts on this or is it in my head
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #2 of 16 (permalink) Old 09-10-2009, 04:02 AM
Re: hot side map sensor
Your giving away my secrets! I did this on mine a couple years ago for the same reason. I still have the boost in the cold side, but the MAP in the hot side.
99 F350 CCLB
skav is offline
post #3 of 16 (permalink) Old 09-10-2009, 06:03 AM
What else?
smokyred's Avatar
That is the way my truck is as well.
Dave
smokyred is offline
post #4 of 16 (permalink) Old 09-10-2009, 06:28 AM
Team Shade-Tree Mechanic
Mini-Stroke...'s Avatar
Send a message via AIM to Mini-Stroke...
Could yall elaborate a little please for a newbie? Can this be done to an OBS?
96 PSD 4X4, 33's, intake, 4" straight exhaust, Autometer NV gauges, Edge
, ZF5 tranny, LUK clutch. D60 swap in the works......
87 Diesel ranger 4X4
Mini-Stroke... is offline
post #5 of 16 (permalink) Old 09-10-2009, 06:09 PM
You don't have an intercooler so no. There was at one time a movement to reference the map in place of the EBPS but the maps were getting damaged from the exhaust soot. So that soon fell to the wayside.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #6 of 16 (permalink) Old 09-10-2009, 06:12 PM
silly question where did you tap into the hot side at?
tch.280 is offline
post #7 of 16 (permalink) Old 09-10-2009, 06:14 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Yours is on the hot side...
Mines been that way for about 6-8 months...
Joe
CSIPSD is offline
post #8 of 16 (permalink) Old 09-10-2009, 06:17 PM
I heard of this mod a few months ago. CSIPSD did had a nice write up but never came back with any logs or data showing the gains.
Where you at CSIPSD?
2000 F350 CC SB Lariate
Afew exstras
All brought together by Tony Wildman
Dale
SZYD is offline
post #9 of 16 (permalink) Old 09-10-2009, 06:45 PM
CSIPSD's Avatar
I was right above you...
I was working on some data logging when I blew up... its been about 5 months now. Getting closer.
Maybe this mod was the one that pushed me over the 500hp limit and cracked the block...
I should have had my toons updates...
Joe
CSIPSD is offline
post #10 of 16 (permalink) Old 09-10-2009, 06:56 PM
I have mine this way, it just reads the boost sooner.
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
outlaw5.0 is offline
