Nitrous on a stock motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 09-09-2009, 06:45 PM Thread Starter
What shot of nitrous is good on a truck with the stock injectors, basic intake, exhaust, 6 pos chip on the 140hp mode? In that mode I am dumping black smoke so I'm sure there is fuel available to be burned. Would a 100 dry shot clear this up or is that too much? Thanks
makaveli200369 is offline
post #2 of 27 (permalink) Old 09-09-2009, 06:49 PM
Peon
jvencius's Avatar
Re: Nitrous on a stock motor
zero
jvencius is offline
post #3 of 27 (permalink) Old 09-09-2009, 06:53 PM Thread Starter
how about a better reply?
post #4 of 27 (permalink) Old 09-09-2009, 06:55 PM
Banned
I don't think it matters.
Charles is offline
post #5 of 27 (permalink) Old 09-09-2009, 07:02 PM
73smoker's Avatar
i would run around a 75 jet i did it for years with no problem but you may have to adjust as necessary to get it to your liking
2000 PSD 6" lift, 35" bfg TKO, 6" stacks, pro comp traction bars, 238 hybrids with 200% nozzles, k&n cold air, s476, irate t4, head studs, TDP custom chip, FASS SYSTEM,ITP fuel bowl delete and regulated return, 20* swamps hpop,custom transmission,chromoly axles,chromoly push rods and high rev springs from Carson Stauffer,and some giggly juice
73smoker is offline
post #6 of 27 (permalink) Old 09-09-2009, 07:08 PM
Moderator
Blowby's Avatar
Well since you have not provided any vital information on your truck the answer is difficult.
With "PMR's" Don't do it!
With "Forged Rods" you can add a little maybe a .030-.040 (with adjusted programing) but it will probably not clean up all the smoke and the cylinder pressure will cause problems you don't want.
So it's best to not use it unless the engine is set up for it.
Blowby is offline
post #7 of 27 (permalink) Old 09-09-2009, 07:09 PM Thread Starter
Thanks for the info. Although I know the stock injectors aren't good for much more then 300HP. Since it is pumping black smoke out in 140mode I know the turbo isn't supplying enough air to burn all the fuel up. So I just wanted to use a small shot to clear that up and balance it. It is a forged rod motor late 99
post #8 of 27 (permalink) Old 09-09-2009, 07:22 PM
secondarychaos's Avatar
perhaps you should try to diagnose your black smoke issue. you should be cleaning it all up.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #9 of 27 (permalink) Old 09-09-2009, 07:30 PM
HEARING IMPAIRED
'powerstroke7.3's Avatar
Stockers can make more than 300. Maybe you should look into a turbo. Unless its just that badazz NOS sticker you want.
2003 PSD 7.3 L, STRAIGHT PIPE, BD POWER DIGITAL X-MONIOR, TS 6 POS CHIP, BHAF, IDM MOD, 10K MOD, SOME CHROME.
'75 F-100 Custom. Restoration/Project Build
Daniel
I have enough stickers to make 400HP
'powerstroke7.3 is offline
post #10 of 27 (permalink) Old 09-09-2009, 07:43 PM
Back to Civilian Life!!
MILFORD's Avatar
get a 38R on there instead. That will clear ya up
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
