Van Turbo Rebuild?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-08-2009, 07:00 PM Thread Starter
Van Turbo Rebuild??
Ok so i finally got a hold of a van turbo and have some questions about doing the swap.. Gonna go ahead and do the pedestal swap and put a WW in it.. where can i get a rebuild kit for this turbo or will the standard 7.3L rebuild kit work with it???
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #2 of 7 (permalink) Old 09-08-2009, 07:20 PM
Send a message via AIM to JohnT
Re: Van Turbo Rebuild??
Do not put the Wicked Wheel in it, you will flow less air with it.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #3 of 7 (permalink) Old 09-08-2009, 10:44 PM
aklim's Avatar
Can you just send it out to Ron's Turbo Service? Rebuilt Turbochargers| Turbocharger Kits| Turbochargers| Salt Lake City, Utah
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #4 of 7 (permalink) Old 09-11-2009, 12:26 AM Thread Starter
ok so im gonna be putting my van turbo on this weekend.. does the wastegate actuator go back on the van turbo or do you leave it off? and if so then were does my red line plug into if its removed?
post #5 of 7 (permalink) Old 09-11-2009, 12:48 AM
aklim's Avatar
What wastegate actuator? You should have no actuator at this time. Did you get the exhaust flange that you needed?
I would remove the lines itself and leave the electronic doohicky alone so it doesn't trip a code and plug up where it goes into the manifold.
aklim is offline
post #6 of 7 (permalink) Old 09-11-2009, 04:41 AM
jkidd_39's Avatar
The van turbo uses the same rebuild kit as the stock 7.3 turbo. GP38 if I recall correctly.
2002 F-350 CCLB 7.3 250,000 Miles *** 5" MKO Power Exhaust, 6637, Foil Delete, DB's HT Starter, EV2 Gauges, 6.0 IC/TC, Van Turbo, WW, Casserly Stg. 1 Singles, BTS VB, DP Tuner, HPX***
2008 F-450 CCDRW 80k ***4"DP-5"MBRP, S&B Intake, Elite EGR delete w/ wastegate, Elite Studs, DPF/DOC delete, KEM 345***
jkidd_39 is offline
post #7 of 7 (permalink) Old 09-11-2009, 03:56 PM
<---- my shop
vader's fury's Avatar
the stock turbo rebuild kit will work just fine. dont use the WW it will cut down on air flow. You will not have a wastegate on the van turbo, Just remove the red line that went to the wastegate and cap it off at the intake spyder where it attaches
vader's fury is offline
