How much boost is everyone hitting on stock turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 116 (permalink) Old 09-06-2009, 12:54 AM Thread Starter
Tonkatruck's Avatar
I was wondering what everyone is hitting and what I should be running. If I remember correctly my Excursion would hit 25-27lbs with DP tuner and tymar. My current truck will not go past 20lbs. Was wondering is it because of the Banks wastegate? Should I adjust it?
2002 F-350 CC LB Silver 10 inch lift on 38x13.50x20 Toyo MT's, Banks stinger kit, 4" exhaust, Intake, Big head waste gate, DP live tuned 12 pos chip, Transgo Shift kit, 6.0 trans cooler, 4 pod gauges. All work done at WOP
2003 Super air Nautique Team edition
SOLD 02 Ex Blk on Tan Limited. 7.3
SOLD 97 White F-350 CC 12 inch lift 38.5X15.50
Tonkatruck is offline
post #2 of 116 (permalink) Old 09-06-2009, 01:42 AM
treyloco's Avatar
Re: How much boost is everyone hitting on stock turbo?
On a stock wastegate I will hit about 29-30 psi. I would adjust it.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #3 of 116 (permalink) Old 09-06-2009, 01:44 AM
ARMY bound
Just disconnect the wastegate...
bbbxcursion is offline
post #4 of 116 (permalink) Old 09-06-2009, 01:51 AM
99 7.3's Avatar
09 6.7 cummins w/ a couple things
99 7.3 is offline
post #5 of 116 (permalink) Old 09-06-2009, 02:04 AM
it's an 02 05 08
turbodiesel_02's Avatar
I hit 25 with my superchip on performance and my waste gate plugged in
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #6 of 116 (permalink) Old 09-06-2009, 02:29 AM
mine will go 30-32 with the "boost tube" on it, which is basically disconnecting the wastegate. Otherwise, 25psi
2000 F250 Red CCSB.Full Force 238/100s, BTS valve body, T-500. Normal bolt on stuff.
"Because HE Lives..."
bigfords is offline
post #7 of 116 (permalink) Old 09-06-2009, 03:31 AM
War Pig
Caballo Diablo's Avatar
I can get to 27 psi. Which seems low for what I'm running, I would think I should be higher.
Chad
04 F350, CC, LB, 4X4 Fat Bottom Girl....Butt A$$ Stock
SOLD>>>'00 F250, DP-Tuner, 5" Straight Pipe, S&B intake, autometer, Racer X TC and VB, Full Force Stage 1, prepump/in-tank mod, Annihilator, 203*
ET: 5.024 250' Mud Track
Caballo Diablo is offline
post #8 of 116 (permalink) Old 09-06-2009, 03:41 AM
Send a message via AIM to JohnT
Mine is hitting 28psi and I am unhappy. Because over 25 is pissing in the wind. I have to adjust my wastegate.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #9 of 116 (permalink) Old 09-06-2009, 04:51 AM
Village Idiot
southmike's Avatar
do you have a wicked wheel chad?
southmike is offline
post #10 of 116 (permalink) Old 09-06-2009, 08:15 AM
TRX370r's Avatar
27-28 PSI here but I just blew it up last week too!
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
