I just finished the install on my CMGS stage three kit. I added the flow sensor, solenoid and 3 port manifold. I am using a single 250
psi pump and 3 250cc nozzles. 1 in each runner of the Y and the last nozzle just before the Y.
I set the program to run off boost and
EGT. The system will come on at 50% when I hit 12
psi and 1050EGT. The system reached 100% at 25
psi and 1300EGT. I set it to come on at 50% because I wanted to make sure the nozzles were atomizing well. Also, because I used 3 nozzles instead of 2.
I've been playing w it for a couple of days, and I almost think that I should get more water.
WOT, I got past 1500EGTs. I am going to do a couple more runs to see how high the
EGTs get, but I'd like to keep them around 1450-1500 max at
WOT.
I am thinking of getting another 250
psi pump, a 30
psi hobs switch, and switch it from the dash to a relay. On this pump, I'd run another 2 nozzles before the Y. I'm not sure if I should use 250cc nozzles or go bigger.
Any suggestions/ ideas?
I'd like to hear what kind of water setups people are using, and what size nozzles.
Thanks,
Sean
