Tips for best 1/4 mile pass. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 09-04-2009, 05:36 AM Thread Starter
Tonkatruck's Avatar
You can view my mods below. What should I brake boost to before launch? Also any little tricks to get the best time possible?
Running tomorrow at Weekend on the edge.
2002 F-350 CC LB Silver 10 inch lift on 38x13.50x20 Toyo MT's, Banks stinger kit, 4" exhaust, Intake, Big head waste gate, DP live tuned 12 pos chip, Transgo Shift kit, 6.0 trans cooler, 4 pod gauges. All work done at WOP
2003 Super air Nautique Team edition
SOLD 02 Ex Blk on Tan Limited. 7.3
SOLD 97 White F-350 CC 12 inch lift 38.5X15.50
Tonkatruck is offline
post #2 of 24 (permalink) Old 09-04-2009, 01:09 PM
theSLEEPER's Avatar
theSLEEPER is offline
post #3 of 24 (permalink) Old 09-04-2009, 01:15 PM
A Ghost these days...
farm boy's Avatar
Re: Tips for best 1/4 mile pass.
Ditch the 41's.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #4 of 24 (permalink) Old 09-04-2009, 02:06 PM
28 cent #2
daryl4412's Avatar
Hope you got traction bars because with all that lift I know you have axle wrap. It will be hell on it trying to boosted launch with those 41's. Good luck!
daryl4412 is offline
post #5 of 24 (permalink) Old 09-04-2009, 03:38 PM Thread Starter
Tonkatruck's Avatar
I have never had axle wrap. What is that? What should I boost to before launch what RPM? What tune should I run?
This is my list.
Position 0: No-Start
Position 1: Stock
Position 2: Drive-Thru
Position 3: Hi-Idle 1200 RPM
Position 4: 60hp Tow
Position 5: DECEL
Position 6: 80hp Tow
Position 7: 60hp Econo
Position 8: 80hp Econo
Position 9: 120hp Race
Position A: 140hp Extreme
Position B: 140hp Aggressive
Position C: Smoke
post #6 of 24 (permalink) Old 09-04-2009, 03:50 PM
Well Hung Member
stroked's Avatar
as far as i last knew 140 aggressive and smoke were the same program, but clearly youre going to want to run in your highest hp program. so probably looking to be position B. 4 wheel high, boost about as much as you can without driving through the brakes, and launch at the last yellow light, do it right youll have low reaction times, and wont redlight, then just keep it on the track with your foot on the floor
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #7 of 24 (permalink) Old 09-04-2009, 04:05 PM
There's nothing wrong with 80E. I would try sveral different tunes just to see what they did. I bet there's not much difference. My 80E and 140E doesn't have much difference. I've been running them for nearly 5 years and over 100K miles. I have tried some other tunes from other people and they just don't perform as well.
David Willingham
Advanced Motorsports Engineering
_____________________________________________
2001 F250 Lariat, CC, 4x4, 7.3L, ZF6-to-auto swap, 3.73, Jody's 60T, 80E, 140E, GTP38R, Reg return
ProF100 is offline
post #8 of 24 (permalink) Old 09-04-2009, 04:19 PM
28 cent #2
daryl4412's Avatar
Axle wrap is when your yoke is being pushed up from your truck taking off or accerrating. Your axle is trying to shift under accerlation. I assure the truck has some being as mine is stock in the rear and had a little axle wrap. Didnt realize it till I added some 7' bars.
post #9 of 24 (permalink) Old 09-04-2009, 04:25 PM Thread Starter
Tonkatruck's Avatar
I won't run in 4 high I get a clunking sound when it's in 4 high right now and it can't be solved. It's been in the shop 3 times and hasn't gone away.
Also Jody made a smoke tune above 140 aggressive. Someone wanted a little more smoke so he made another tune.
post #10 of 24 (permalink) Old 09-04-2009, 04:52 PM Thread Starter
Tonkatruck's Avatar
Not running. I guess you can't be above 36" to crank. My truck is at 47"
