DIY high idle mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 09-03-2009, 05:05 PM Thread Starter
hyrk's Avatar
DIY high idle mod
Been searching around for this mod, and found some different ways to do it. Some more complicated than others, some date back to 2002. Anyone have something upto date, simple, and effective?
Thanks
2002 F-350, S&B intake, 38R tubro w/ wwII, EBV delete, CFM manifold, Spearco i/c, Adrenaline HPOP, Casserly stage I AC injectors , ITP Reg. return, DI Headers, hutch fuel mod, Cooling mist stg. 3, 4" MBRP Exhaust, transflow 46 and 40 gal fuel tanks/tool chest, Tunes by GAP, 4" pc lift, 22" Tis 534 wheels w/37"x 13.5" Dakar MT's, 4.30 gears
hyrk is offline
post #2 of 20 (permalink) Old 09-03-2009, 05:06 PM
theSLEEPER's Avatar
Re: DIY high idle mod
Add it to your F6???
theSLEEPER is offline
post #3 of 20 (permalink) Old 09-03-2009, 05:22 PM Thread Starter
hyrk's Avatar
Oh yeah i should of mentioned that... i talked to jody about adding it to my f6, He suggested the DIY method as it wouldnt have to switch the pcm each time i need the high idle.....He must know how cold it gets up here in CAN. lol
hyrk is offline
post #4 of 20 (permalink) Old 09-03-2009, 05:27 PM
theSLEEPER's Avatar
Ohhh... OK.
post #5 of 20 (permalink) Old 09-03-2009, 05:31 PM Thread Starter
hyrk's Avatar
Originally Posted by theSLEEPER View Post
Ohhh... OK.
Thats exactly what i said. Thought he might have a chance to make some $$. But steered me a different way.
hyrk is offline
post #6 of 20 (permalink) Old 09-03-2009, 05:41 PM
do what i did if you have a 4x4 truck with the manual shifter, notch a 2x4 so it wont slip on the shifter then cut it to lengh. i cut mine so i was able to move it up and down on the shifter so mine could idle where i wanted it.
02 f250
countryboyrob is offline
post #7 of 20 (permalink) Old 09-03-2009, 06:28 PM
PSN Pretender
907DAVE's Avatar
Go get a PTO controller from a wrecking yard, can be had for around $50.
907DAVE is offline
post #8 of 20 (permalink) Old 09-03-2009, 09:03 PM Thread Starter
hyrk's Avatar
I figure every 1/4" notch should give me about 100 rpm. Getting on my recip. saw right now. Thanks lol
hyrk is offline
post #9 of 20 (permalink) Old 09-03-2009, 11:49 PM
Maybe Jody was thinking you had an 05+ . Update your F6 and be done with it.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #10 of 20 (permalink) Old 09-04-2009, 12:49 AM
Dead Member
Marauder's Avatar
+1 Had it programed on my F5 @ 1800 rpm. I drop my truck into 4L set the chip and trail through the dessert. It also help the batteries on a cold morning when unloading the bikes and running the lights on the trailer in the pits.
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
