Has there been any "TECHNICAL testing..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 07-29-2007, 01:52 PM Thread Starter
Body Type: MULE
CATdiezel's Avatar
Of the new BB turbo from Turbonetics other than just throwing one on and saying "YUP" in my best Hank Hill voice.....
Specifically drive pressure ratio's with different housings, ect?
IM almost sure someone has....specifically turbonetics themselves maybe
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
CATdiezel is offline
post #2 of 31 (permalink) Old 07-29-2007, 07:46 PM
OEM Moderator
Tom S's Avatar
Re: Has there been any "TECHNICAL testing.....
I think that they are just too new for that data to have been gathered yet. But if my understanding is correct it should be very similar to the results seen with the regular drop in TN as the BB just has the upgraded center section. I hope that either of the Brians see this and clarify the information.
Tom
Tom S is offline
post #3 of 31 (permalink) Old 07-29-2007, 07:52 PM Thread Starter
Body Type: MULE
CATdiezel's Avatar
I am patiently awaiting
post #4 of 31 (permalink) Old 07-29-2007, 08:01 PM
DarkShadowDiesel's Avatar
i think they were testing it last week on a stock truck, and gene was testing one too. i believe it was going on an upgraded truck in iowa soon if it's not already on there
DarkShadowDiesel is offline
post #5 of 31 (permalink) Old 07-29-2007, 08:07 PM
Since nothing changed other than the bearing housing, I don't know why the drive pressure would be different than the other unit-which is well documented.
With the low temps we are seeing, drive pressures are low. We'll get more later.
bbunting is offline
post #6 of 31 (permalink) Old 07-29-2007, 09:00 PM Thread Starter
Body Type: MULE
CATdiezel's Avatar
That helps.
I did not realize that it was the same turbo just a different center section.
If thats the case then enough said, but if the center section is more efficient then maybe the drive ratio might be a lil different.
I guess I should have picked that up when it was stated that the other guys could "upgrade" there center section.
post #7 of 31 (permalink) Old 07-30-2007, 08:40 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
I believe Weweld is running around with one. Might wanna pm him.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #8 of 31 (permalink) Old 07-30-2007, 10:08 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I tested mine with both the 38r with the 1.0 and the 1.15, TN with 1.00 and .84 housings...
I'll just give the MAX boost to MAX drive pressures...
38r at 36#'s boost was about 50-54#'s drive with the 1.00 housing...
38r at 34#'s boost was about 38-40#'s drive with the 1.15 housing...
TN at 34-36#'s boost was at 36-38#'s drive with the 1.00 housing...
TN at 34-36#'s boost was at 40-42#'s drive with the .84 housing...
Dont have a BB to test yet but I hope to get one and run all three housings on it... If it spools as good as I have heard the the 1.15 housing might be a SWEET set up...
Joe
CSIPSD is offline
post #9 of 31 (permalink) Old 07-30-2007, 10:43 PM
whatever, the empirical evidence shows it doesn't leak like &#37;$#^ garretts!!!!!!!!!!!!!!!!!!!!!!!!!!!! :supergay:
oops, maybe this belongs in the oil leak thread...
post #10 of 31 (permalink) Old 07-30-2007, 10:55 PM
CSIPSD's Avatar
Originally Posted by DarkShadowDiesel View Post
whatever, the empirical evidence shows it doesn't leak like %$#^ garretts!!!!!!!!!!!!!!!!!!!!!!!!!!!! :supergay:
You know I forgot to mention that... The Garrett leaked oil on every test... every day... every time...
Joe
CSIPSD is offline
