Truck is running like a pos , choppy - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-02-2009, 03:56 AM Thread Starter
StroKer01's Avatar
HEY GUYS.
Ok so I have my dp back , And still my truck is running like a pos! Idle will go up and down, And the truck is running really rough and choppy o most like it is missing or something,Could it be some wire i forgot to plug in? I do not know why this is and was hopping that with any luck a few of you guys would know or would try and help me with this !?!?
THANKS
TO MUCH FORD POWER!
2002 chevy Dmax PPE hot+2
1995 Power stroke .SD swap
Rangers lead the way
StroKer01 is offline
post #2 of 13 (permalink) Old 09-02-2009, 04:21 AM
What else?
smokyred's Avatar
Re: Truck is running like a pos , choppy
If it runs better without the chip in, then it would be very likely it's the chip/tuner.
Who's injectors are you running, and/or what mods?
Dave
smokyred is offline
post #3 of 13 (permalink) Old 09-02-2009, 04:57 AM Thread Starter
StroKer01's Avatar
No it crapyer with out the chip, Ha but still really bad with it And there from ddp there stage two's and I don't have many mods chip,intake. 6.0 intercooler ats turbo houseing and x wheel
TO MUCH FORD POWER!
post #4 of 13 (permalink) Old 09-02-2009, 07:01 AM
HP Junky
Anyway you can do an injector buzz test or just an overall scan of the truck? Maybe an injector harness has come loose or something. Any check engine lights?
RockinJW is offline
post #5 of 13 (permalink) Old 09-02-2009, 02:14 PM
SeeYa's Avatar
Originally Posted by StroKer01 View Post
HEY GUYS.
THANKS
Which wires were you messing with?
Try checking:
IPR sensor
ICP Sensor
UCVH(make sure it hasn't come unplugged)
Contribution test
What CPS do you have?
Diane
SeeYa is offline
post #6 of 13 (permalink) Old 09-02-2009, 02:43 PM Thread Starter
StroKer01's Avatar
I ment like maybe when I was putting the injectors in ,maybe a wire plug come un done or something
TO MUCH FORD POWER!
post #7 of 13 (permalink) Old 09-02-2009, 02:45 PM
SeeYa's Avatar
Did you check it?
SeeYa is offline
post #8 of 13 (permalink) Old 09-02-2009, 02:48 PM
You need to get it on a scanner.
2000 F350 CC SB Lariate
Afew exstras
All brought together by Tony Wildman
Dale
SZYD is offline
post #9 of 13 (permalink) Old 09-03-2009, 02:16 AM
Village Idiot
southmike's Avatar
did you go from splits to singles etc.... and not tell the tuner
also double check the inj harness
southmike is offline
post #10 of 13 (permalink) Old 09-03-2009, 02:20 AM
fueled by Colecovision
golfer's Avatar
Garage
sounds like bad injectors or an engine with no compression.
any SES lights on? (if not, then it's nothing electrical with the injectors< though it could be something mechanically jacked within them)
chip tuning can't really make an engine miss or not miss
golfer is offline
