AIH Delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-30-2009, 05:58 PM Thread Starter
cntryboy17's Avatar
AIH Delete
Those of you running a aih delete how does it act in the cold? I was thinking about doing it but dont want to lose relability in the winter. Is it harder to start in the winter?
E99 F-350 CCSB 4x4
1990 F250 7.3idi 4x4 5 speed- SOLD!
cntryboy17 is offline
post #2 of 8 (permalink) Old 08-30-2009, 07:39 PM
ARMY bound
Re: AIH Delete
I never noticed any difference in the winter when I lived in chicago.
bbbxcursion is offline
post #3 of 8 (permalink) Old 08-31-2009, 02:01 AM
Re: AIH Delete
Absolutely, positively no friggin difference and I live in NY.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #4 of 8 (permalink) Old 08-31-2009, 02:46 AM
Re: AIH Delete
no difference..............
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #5 of 8 (permalink) Old 08-31-2009, 10:17 PM Thread Starter
cntryboy17's Avatar
Re: AIH Delete
Alrighty thanks i didnt want to do it then have problems in the winter and having to resort to driving the gasser. lol
E99 F-350 CCSB 4x4
post #6 of 8 (permalink) Old 08-31-2009, 10:59 PM
CtG
Re: AIH Delete
She started on a block-heaterless morning with a -40F windchill last winter.... Then gelled up and died. Lol... So with good working glow plugs and glow plug relay you should be just fine. Just make sure if its cold enough to use an additive... Which applies regardless.
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #7 of 8 (permalink) Old 08-31-2009, 11:58 PM
Re: AIH Delete
AIH has nothing to do with starting.
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #8 of 8 (permalink) Old 09-01-2009, 12:27 AM
<-- GO BRONCOS
dblamp's Avatar
Re: AIH Delete
These are the requirements for AIH activation on PSDs: (From Bob Riley's DieselSite web page)
FAQ: What is the real purpose of the intake heater, and when does Ford say it will operate normally?
"To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated: "
ambient temperature must be below 0 deg C (32 deg F)
engine oil temperature must be below 55 deg C (131 deg F)
vehicle power must be between 11.8 and 15 volts
parking brake must be applied on manual transmission vehicles
the transmission must be on park or neutral on automatic transmission vehicles
glow plugs must be off
It is a very specific set of circumstances. You wont miss it. It will throw a soft code, but wont hurt anything.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
