white smoke? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-28-2009, 08:13 PM Thread Starter
white smoke?
Here's a question--need some answers!
I just put a new turbo on my truck (see signature for details) and it blows white smoke now. It blew white at idle and low speeds until I got onto the throttle and then went back to the normal black smoke I am used to seeing. Anyone have any suggestions on why it is doing this now or if it is normal now that I upgraded the turbo?
02 F350 4x4
foxhole73 is offline
post #2 of 9 (permalink) Old 08-30-2009, 07:27 AM Thread Starter
Re: white smoke?
does anyone have an idea?
02 F350 4x4
post #3 of 9 (permalink) Old 08-31-2009, 05:01 PM
<-- GO BRONCOS
dblamp's Avatar
Re: white smoke?
Why are you still using the superchips programer with a custom chip?
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #4 of 9 (permalink) Old 08-31-2009, 08:38 PM
matthewd11's Avatar
Re: white smoke?
Did the exhaust housing/wheel look damp with oil at all before you installed it? Sounds like the seals may be leaking...
matthewd11 is offline
post #5 of 9 (permalink) Old 08-31-2009, 09:35 PM Thread Starter
Re: white smoke?
idk i never thought about it. will it make a differents? i got the chip when i got my injectors
i found out what it was. the return line have 2 kinks in the line and the oil couldnt pass thru.
02 F350 4x4
post #6 of 9 (permalink) Old 08-31-2009, 09:37 PM
Stroker67's Avatar
Re: white smoke?
Man unstack those chips, after all your not driving a dodge
Stroker67 is offline
post #7 of 9 (permalink) Old 09-01-2009, 12:21 AM
<-- GO BRONCOS
dblamp's Avatar
Re: white smoke?
The chip over-rides any programmer you stack with it.
Anthony
dblamp is offline
post #8 of 9 (permalink) Old 09-01-2009, 12:29 AM Thread Starter
Re: white smoke?
ok i just got it off
02 F350 4x4
post #9 of 9 (permalink) Old 09-01-2009, 12:30 AM Thread Starter
Re: white smoke?
thanks for the input
02 F350 4x4
