910 valve springs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-28-2009, 01:33 AM Thread Starter
co04cobra's Avatar
910 valve springs
I did do a search but couldnt come up w/ it. I was wondering how long (a general idea) I should allow to install a set of 910 valve springs and pushrods one night. Thanks
co04cobra is offline
post #2 of 13 (permalink) Old 08-28-2009, 01:40 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: 910 valve springs
better figure on a weekend
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #3 of 13 (permalink) Old 08-28-2009, 02:11 AM
Busy Busy
Marty's Avatar
IF you have done valve springs before it can be done in a night... the pushrods are easy, you just have to go slow because of turning the motor over. If this is your first time then better figure a weekend.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 13 (permalink) Old 08-28-2009, 04:06 AM
Layson's Avatar
Kinda like surgury... those dang little keeper pins...
Layson is offline
post #5 of 13 (permalink) Old 08-28-2009, 04:10 AM
Busy Busy
Marty's Avatar
What he said... a small magnetic telescoping pole is A MUST.
Elkton, Maryland
Marty is offline
post #6 of 13 (permalink) Old 08-28-2009, 04:37 AM
Milk Truck
abianca99's Avatar
99.5 F250 cclb 4x4...modded, but looks stock
abianca99 is offline
post #7 of 13 (permalink) Old 08-28-2009, 05:46 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
if you have done it before about 2-2.5 hrs w/ the motor on the floor.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #8 of 13 (permalink) Old 08-28-2009, 07:40 AM
99 7.3's Avatar
ya shouldn't take that long as long as the engine is out. however if its in the hole, different story. easier yet w/ the heads off!!!! good luck
09 6.7 cummins w/ a couple things
99 7.3 is offline
post #9 of 13 (permalink) Old 08-28-2009, 07:45 AM
just did one in the truck. took me 4 hours. that a/c box is a b!tch to get around but it can be done. just depends on how good ya are on stuff. id give a day to do it if ya got the tools tho.
SIR-STROKEALOT is offline
post #10 of 13 (permalink) Old 08-28-2009, 08:32 PM Thread Starter
co04cobra's Avatar
Damn maybe I should just pull the cab...
