turbo question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-27-2009, 02:42 PM Thread Starter
you want some of this?
smorris's Avatar
turbo question
Okay, got a couple turbos yetserday wondering what they were.
Its a detroit deisel- allison turbocharger with a part # of
5103875 compressor a/r .96 exhaust a/r 1.14
Has air research stamped in the side.
Anyone ever seen one of these before? Looks to be about the right size for the big charger in a set of compounds. 3.5 inlet on compressor 3.875 or so outlet on the turbine side.
Since no one can seem to rate turbo sizes the same way I still have yet to understand all the different numbers.
Could be a little big, or maybe not. I got two of them , and both seem to be in very good condition , came off a cummins power genset. Two v-8's bolted toether to make a v-16 with four of these turbos on there.
Scott
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #2 of 3 (permalink) Old 08-27-2009, 10:04 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: turbo question
Turbo: T18A40
Part Number: 407370-6
MFGR: GARRETT
Description: DETROIT 5103875
Compressor: 0.96
Turbine: 1.14
Trim: 55
from: http://www.turboparts.info/images/inventorypdflist.pdf
Applications: ENGINES AND POWER UNITS
Mark: DETROIT DIESEL
Type: 29302
Engine: 12V149T
Family Turbo: T18A40
Turbo Code: 407370-0006
OEM turbo code: 5103875
from:DETROIT DIESEL turbochargers, DETROIT DIESEL turbo, DETROIT DIESEL turbocharger, DETROIT DIESEL diesel injection
Engine: 12V149T
Cylinders: 12V
CC: 29302
Model: T18A40
Part Number: 407370-0006
EOM part number: 5103875
from: GARRETT turbos for Detroit Diesel Engines and Power Units - Applications - TurboMaster
12V149T:
Hoss Equipment - Photo Gallery
Go ARMY!
cowboy_dan is offline
post #3 of 3 (permalink) Old 08-27-2009, 11:27 PM Thread Starter
smorris's Avatar
Re: turbo question
Yup thats it. Thanks.
Now if I can just get all four to fit under the hood....along with something to make enough drive pressure to turn them.
smorris is offline
