boost and egt's on my 02 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 08-27-2009, 01:47 AM Thread Starter
it's an 02 05 08
turbodiesel_02's Avatar
got my gauges in and was wondering what the average egt's and boost reading's are for the 7.3,I am runnin the performance tune on my flash paq about 100hp
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #2 of 27 (permalink) Old 08-27-2009, 02:28 AM
mnstroker's Avatar
Re: boost and egt's on my 02 7.3
I bury my 35 psi boost guage so no help there. EGT's will go as far as you let them.
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #3 of 27 (permalink) Old 08-27-2009, 02:35 AM
You dont want it to see more than 13000 for to long and you probably wont see any more that 25 to 30PSI
SZYD is offline
post #4 of 27 (permalink) Old 08-27-2009, 04:29 AM
Village Idiot
southmike's Avatar
err... 1300
def dont want to see 13,000...ever
hit the zero key to many times
southmike is offline
post #5 of 27 (permalink) Old 08-27-2009, 05:07 PM
Originally Posted by southmike View Post
err... 1300
Yep that would be bad
2000 F350 CC SB Lariate
Afew exstras
All brought together by Tony Wildman
Dale
SZYD is offline
post #6 of 27 (permalink) Old 08-31-2009, 06:14 AM
gstcshooter's Avatar
you should be pushing around 30psi on a stock turbo. and your egt's shouldn't go above 1200 because any higher then you can start to have severe engine damage
e99 F250 a few extras
gstcshooter is offline
post #7 of 27 (permalink) Old 08-31-2009, 08:09 AM
30 PSI stock? I only push 15 stock, and from what I hear that is not uncommon...
Morningstar908 is offline
post #8 of 27 (permalink) Old 08-31-2009, 10:09 AM
ottskee's Avatar
Location: born and raised in ohio but stationed in cali right now
I get up to 25 on the strip. Normal cruising though its about 15 stock.
01' F-250, S&B intake,TS Performance 6 pos chip,5" aussie stacks, ITP RR, Airdog 100, Garret 38R, John Wood Trans
ottskee is offline
post #9 of 27 (permalink) Old 09-01-2009, 12:46 AM
If you are only pushing 15 psi with a tuner of any sort, you need to be looking at your up pipes and intercooler boots for leaks. 25 psi should be no problem.
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc singles with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes.
calebgriffin31 is offline
post #10 of 27 (permalink) Old 09-01-2009, 12:56 AM Thread Starter
it's an 02 05 08
i am pushin 25 psi with it at wot and usually around 15 driving normally
