Power Curves - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 46 (permalink) Old 08-26-2009, 08:34 PM Thread Starter
Powerstroke Racer's Avatar
Power Curves
Just when we were getting somewhere someones panties got in a knot.
Everybody take out a sheet of paper, now lay it sideways. Now starting at the lower left corner(idle)draw a line of what you feel in the throttle toward the right side of the sheet(WOT) and post what you drew.
Powerstroke Racer is offline
post #2 of 46 (permalink) Old 08-26-2009, 08:37 PM
Re: Power Curves
Here is mine again, you get the idea:
mattr66 is offline
post #3 of 46 (permalink) Old 08-26-2009, 08:43 PM
The Fireman
big_stroker's Avatar
Re: Power Curves
Mine looks just like Matt's drawing since I run his tuning.
big_stroker is offline
post #4 of 46 (permalink) Old 08-26-2009, 08:51 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Power Curves
Here is what mine felt like when it ran...
Joe
CSIPSD is offline
post #5 of 46 (permalink) Old 08-26-2009, 08:54 PM
ARMY bound
Re: Power Curves
Mine hit hard as fuk on the low end. I mean HARD!
bbbxcursion is offline
post #6 of 46 (permalink) Old 08-26-2009, 08:55 PM
CSIPSD's Avatar
Re: Power Curves
Yup... then nothing really on top.
Joe
CSIPSD is offline
post #7 of 46 (permalink) Old 08-26-2009, 08:57 PM
ARMY bound
Re: Power Curves
Exactly, it just hit hard then tapered off.
post #8 of 46 (permalink) Old 08-26-2009, 09:04 PM
cchildress's Avatar
Re: Power Curves
Mine hits hard then tapers off. Fuels a shat load on bottom and then just feels like I have another 1" of play in the pedal at the end with not much there.
97 F350, lwb, cc, 4x4
Mods-lots!! To many to list and more to come!!!
Deathrow Inmate #26
cchildress is offline
post #9 of 46 (permalink) Old 08-26-2009, 09:07 PM
theSLEEPER's Avatar
Re: Power Curves
theSLEEPER is offline
post #10 of 46 (permalink) Old 08-26-2009, 09:26 PM
OEM Moderator
Tom S's Avatar
Re: Power Curves
I edited this to get back on track. I will say mine is more like Sleepers in a hot setting and more like Matts in a milder setting without the pee pee on the end.
Tom S is offline
