Installed TurboMaster... ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 08-08-2009, 11:06 PM Thread Starter
just a welding fool.
Hawker's Avatar
A couple days ago i installed the Turbomaster wastegate controller on my truck. after 2 hours of trying to get the clip on (with the turbo still on) i got so fed up i pulled the turbo off. took me all of 30 seconds to get the clip on and the turbo ready to go back on...
anyways, i adjusted the spring to what dieselsite gives as the starting point, but when i pin it, i can still reach 30psi without a problem. should i go even less tension on the spring?
Hawker is offline
post #2 of 2 (permalink) Old 08-09-2009, 04:25 AM
Deputydog's Avatar
Re: Installed TurboMaster... ?'s
If you don't want to see 30 psi, then yes back it off about 2.5783 turns
Deputydog is offline
