Hpop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 08-01-2014, 02:33 AM Thread Starter
7_3sd03's Avatar
Hpop
So the time has come to replace the hpop in my 03 7.3 just wanted some opinions and reviews on anything aftermarket good chance of injectors in future dont want anything stock
7_3sd03 is offline
post #2 of 24 (permalink) Old 08-01-2014, 03:05 AM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Re: Hpop
So, how much you looking (or willing) to spend on said HPOP? That may indicate who's pump you end up with.
(These are always entertaining threads...)
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #3 of 24 (permalink) Old 08-01-2014, 03:27 AM Thread Starter
7_3sd03's Avatar
Re: Hpop
Somewhere in the $600-$900 range maybe more depending one what it is
7_3sd03 is offline
post #4 of 24 (permalink) Old 08-01-2014, 03:57 AM
the stryker god
Re: Hpop
What makes you think you need a new hpop?
bruce51d is offline
post #5 of 24 (permalink) Old 08-01-2014, 04:27 AM
Re: Hpop
Mine is below $600, but don't let the price scare you.
TerminatorEngineering is offline
post #6 of 24 (permalink) Old 08-01-2014, 11:15 AM Thread Starter
7_3sd03's Avatar
Re: Hpop
I dont think I need a hpop I know I need it always sets icp below desired on any kind of pull only putting out 2000psi
7_3sd03 is offline
post #7 of 24 (permalink) Old 08-01-2014, 11:15 AM Thread Starter
7_3sd03's Avatar
Re: Hpop
Are these pumps available readily or do I need to s3nd a core first
7_3sd03 is offline
post #8 of 24 (permalink) Old 08-01-2014, 01:10 PM
Calico5's Avatar
Re: Hpop
http://www.stealthpumps.com/
Al in SoCal
Calico5 is offline
post #9 of 24 (permalink) Old 08-01-2014, 01:45 PM
powerstrokeG38R
Re: Hpop
I have a honey badger Jr. And it keeps up with 238cc 100% great. Over 3000psi
99.5 F350 6speed = home made stage2 afe intake,G38R ,duel disc ,new oil pan, dyno proven tunes ,isspro gauges ,4 in down pipe , fuel system,rr kit ,238cc 100%,main studs,hpx,head studs,honey bager jr
powerstrokeG38R is offline
post #10 of 24 (permalink) Old 08-01-2014, 02:18 PM
the stryker god
Re: Hpop
Could be blown injector o-ring, worn out injectors or tunes call in for too much pulse width
bruce51d is offline
