thruster 2 or 38r ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 07-26-2014, 05:25 AM Thread Starter
Colorado's Avatar
thruster 2 or 38r ?
Truck is an 01 350 cclb auto. I'm after towing performance, egt control and low rpm spool. I live at 8000+ ft elevation
97 F350 4x4 - SWAMPS
01 F350 4x4 - SWAMPS
01 F450 4x4 - 4.88's
Colorado is offline
post #2 of 13 (permalink) Old 07-26-2014, 09:25 AM
richyrich's Avatar
Re: thruster 2 or 38r ?
38r cannot be rebuilt just food for thought
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #3 of 13 (permalink) Old 07-26-2014, 02:26 PM
dsberman94's Avatar
^but it also takes a lot of abuse to kill it. Dynoproven has a brute 66 turbo which is basically a rebuild able 38r. Might want to check that out.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #4 of 13 (permalink) Old 07-26-2014, 03:22 PM Thread Starter
Colorado's Avatar
Is the basb a drop in replacement?
Colorado is offline
post #5 of 13 (permalink) Old 07-26-2014, 03:38 PM
the stryker god
No
bruce51d is offline
post #6 of 13 (permalink) Old 07-26-2014, 07:02 PM
We've put 200k on the 38r and it's still running strong. Egts were lower by 200*. Pulls 36lbs. of boost.
hoschtonhauler is offline
post #7 of 13 (permalink) Old 07-26-2014, 11:20 PM
jeremiahmercier's Avatar
hey there local!
-06 CCLB 6.0, studs, heads reworked, studs, dummy plugs, stand pipe, updated stc fitting, egr delete, 6.4 banjos, blue spring, New oil cooler, 40 FICM, stage 1 powermax, and Looney Wild, 4 inch exhaust
SOLD-1996 f250 4x4, ZF5 with BASB and 175/100s
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Dp-Tuner, air heater delete, 4"dp, billet 38R
jeremiahmercier is offline
post #8 of 13 (permalink) Old 07-27-2014, 12:53 AM
whistle tits
ghohouston's Avatar
38r
ghohouston is offline
post #9 of 13 (permalink) Old 07-27-2014, 01:25 AM Thread Starter
Colorado's Avatar
What about spool time? Is it an improvement over stock with nothing else being changed?
Colorado is offline
post #10 of 13 (permalink) Old 07-27-2014, 04:32 PM
whistle tits
ghohouston's Avatar
38r is fine on a stock truck, and it is a ball bearing turbo, so yes, it spools instantly.
