Horsepower/Torque Guess - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-24-2014, 11:32 PM Thread Starter
Hello all,
First off let me say that I am new to the site and thanks for having me. I wanted to see if anyone has a rough estimate of what kind of numbers my truck may be putting out. Need to get gauges and a new hpop before I go and dyno, so just curious for now until I can get actual numbers when funds allow.
My build so far:
2003 Ford F250 Crew Cab Auto FX4 7.3 249k on the clock
4" lift, 35s
Garrett GTP38R Turbo, Non EBV Pedestal and Flange
Unlimited Diesel Stage 1.5 single shot injectors
TS Performance 6 position Chip-Custom tuned by Gearhead Auto (hvy tow, high idle, stealth, economy, street envy, all out)
AFE 4" Turbo back exhaust
Recent glowplugs, injector control module, other sensors, etc.
Diesel Site:
203 degree thermostat
Billet Alum. Thermostat housing
Air Intake Heater plug
Engine boot kit
External transmission filter kit w/ gauge
High pressure oil crossover line
Factory Tech valve body shift kit
Riffraff:
Fuel rail crossover
plenum reinforcing kit
Diesel O rings:
international bellowed up pipes
Fuel crossover system
Stainless T-bolt clams
Anyone have any guesses as to what this thing may be putting out?
Thanks in advance!
danjr is offline
post #2 of 10 (permalink) Old 07-25-2014, 06:32 AM
International Diesel Tech
purplepstroke's Avatar
Re: Horsepower/Torque Guess
I'd say your around the 400 to 410 horsepower range with that setup. oh and welcome to the site!
E99 7.3***230/100 PIS sticks***swamps tuning*** 4" mbrp***t500 HPOP***6637 filter***BTS valve body***racerx torque convertor***di reg return***walbro fuel pump***20x10 fuel hostages with Nitto 305 terra grapplers
purplepstroke is offline
post #3 of 10 (permalink) Old 07-25-2014, 11:08 AM
Here for the party....
What are stage 1.5 injectors?? I really wish people would stop using stage anything, and start using the damn specs of the injector.
2015 Chevrolet Tahoe, Crystal Red Tintcoat, LOADED
2014 Ford Mustang GT, 5.0, Race Red, 6 speed
Currently Stroke-less
Al Mighty is offline
post #4 of 10 (permalink) Old 07-25-2014, 01:07 PM
the stryker god
160/30, as for hp i'd say 380-400
bruce51d is offline
post #5 of 10 (permalink) Old 07-27-2014, 02:42 AM
dadada's Avatar
Rear wheel hp
2001 F-250 4X4 SCSB 7.3 Auto X Codes w/ 2" Hanger/Shackle Drop Kit-38R w/Turbomaster,AFE, T500, Regulated Return, 6.0 Tranny Cooler, JWVB, 4"Exhaust, Hydra w/ Gearhead, PHP, and Powerstruck tunes, Powerstruck 180/100's Live Tuned by Powerstruck and then some!
dadada is offline
post #6 of 10 (permalink) Old 07-27-2014, 04:26 PM
Village Idiot
southmike's Avatar
A good build for that setup. I would not press pmrs .
only thing i would add perfor mance wise would be a billet wheel if even that.
Or maybe a fluid damper...
otherwise drive and enjoy.
my guess would be 380..
you could tweak more with live tunes and all but prob not worth it hp wise.
to get cleaner and safer maybe.
just my 2 pesos
southmike is offline
post #7 of 10 (permalink) Old 07-29-2014, 11:33 PM
Depends on the tuning, but those injectors (if they are 160/30) should be good for right around 400HP.
post #8 of 10 (permalink) Old 08-09-2014, 01:03 AM
I am going to say 360-365rwhp, then with hpop upgrade (SRP 1.1) around 400rwhp
00 Excursion 7.3 (Banks Quick Spool, 3.5" downpipe, Banks Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, Fuel lab pump and reg., Comp 910's, DI Pushrods, IAH delete, Superchips, Riffraff Boost Fooler), Lift, MM Hubs, 35's, 08 diff cover, Hellwig rr. bar
[email protected] 28mpg
572ysc is offline
post #9 of 10 (permalink) Old 08-09-2014, 04:34 AM
It's a 7.3! My guess is 350 RWHP at most.
lenzhotrod is offline
post #10 of 10 (permalink) Old 08-12-2014, 05:17 PM
What does it being a 7.3 have to do with anything??? Their are 7.3 trucks making 600 on fuel all day long running around pretty common nowadays. I don't mean it as you'll more than likely pull up at a redlight next to one sometime this week..but 600 is the new 350-400 for these trucks.
