Excursion fuel tank in a truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-23-2014, 04:55 AM Thread Starter
daddyusmaximus's Avatar
I am wondering about the feasibility of putting a fuel tank from an Excursion in my truck as an aux tank. Ever been done? I can't find it if it has.
99 F-250 Super Duty, 4X4, CCSB. 400+ hp Black Mamba 7.3. Banks Tecni-cooler, 5" turbo-back. ATS 5 Star 4R100, TC & Billit flexplate. 4" lift, Fox Racing Shox, 35" Toyos. Rhino-lined rockers. Leer cap, Yakima rack. Ranch-Hand bumpers, Rigid Industries spots. ARB air lockers, 4.30 gears.
daddyusmaximus is offline
post #2 of 19 (permalink) Old 07-23-2014, 01:47 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Re: Excursion fuel tank in a truck
The excursion tank is in the back, above the diff, correct?
It's probably nearly the same as the tanks in the cab-chassis models. Their tank's are located between the frame rails, above (and slightly behind) the rear diff, right at the tail-end of the frame.
I don't see why it wouldn't be possible...never actually compared the two though.
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #3 of 19 (permalink) Old 07-23-2014, 04:36 PM
'05 Excursion
Term3's Avatar
On the Excursion there is no part of the tank that is directly above the rear axle. To use one on a pickup I believe there's a crossmember you need to move.
Sent from AutoGuide.com App
Term3 is offline
post #4 of 19 (permalink) Old 07-23-2014, 06:42 PM Thread Starter
The x-brace for the spare would have to come out I'm sure. Just trying to figure out if the bed will have to come off. I got custom wood cabinets under a camper shell. That would be a HUGE hassle.
post #5 of 19 (permalink) Old 07-23-2014, 07:22 PM
'05 Excursion
Term3's Avatar
You'll need the tank skid plate also because the tank is strapped to it and the skid plate is bolted to the frame. May be easier to get that one Titan makes.
Term3 is offline
post #6 of 19 (permalink) Old 07-24-2014, 03:14 AM
You will also need an Excursion hitch/receiver. The truck hitch is in the way.
TerminatorEngineering is offline
post #7 of 19 (permalink) Old 07-26-2014, 03:44 AM Thread Starter
That's my plan. Just wondering if I could do both. I'm planning for long dist off road travel.
post #8 of 19 (permalink) Old 07-26-2014, 05:52 PM
'05 Excursion
Term3's Avatar
If you put in the Excursion tank the after axle Titan tank will not fit obviously but you could get Titans replacement tank and swap out your smaller capacity OEM tank. Lot of work and expense, why not just get a cheap in bed tank?
Term3 is offline
post #9 of 19 (permalink) Old 07-27-2014, 12:28 AM Thread Starter
Don't want an in bed tank. I got a short bed, just enough room under the camper shell to sleep. Got the shell done up for camping. There is a removable sleeping platform for day to day use, but no room for a tank. The storage is built in and is difficult to remove and replace. I just leave it in.
post #10 of 19 (permalink) Old 07-28-2014, 03:48 PM
I just replaced my main tank with a Transfer Flow unit. Days work by a talented fabricator/mechanic who'd never done one before. I'm interested in this thread as I'm building my truck for the same purpose. I like the idea of the Excursion tank mod.
Muledude is offline
